Has anyone ever heard about this full range driver?
It was a product of Philips back to 1970s.
Is it any good?
I would appreciate for any info.
Is it any good?
Philips AD5060/SQ8
Here is a link with some info.
http://www.hupse.nl/radio/speakers/AD5060.htm
I don't know German, but it looks like a midrange or "squawker" 130Hz to 10KHz.
Gio.
Gio.
SQ8
any 'sq' on a philips speaker indicates a mid range
w-woofer
t-tweeter
m-fullrange with a wizzer
x-no wizzer
hp-high power
use low power on these for shure
i really like the way philips sound
more philips-
in dutch-
http://www.mfbfreaks.nl
http://www.dssfreaks.nl/artikel/passief/1/imagepages/image2.html
w-woofer
t-tweeter
x-no wizzer
hp-high power
more philips-
in dutch-
Thanks for the information.
I just got two of them. They are great drivers, even they are already more than 30 years old.
Here are photos of AD50600
They have a sealed tube behined. Probably they sound good even without enclosure. However, it lacks low end (well, it is only 5") and has a weak resolution. Maybe I will try to put it in 3D spiral horn configuration and add a tweeter.
Re: Philips AD5060/SQ8
I speak German, but this reads like Swahili.
GG said:I don't know German
Charles,
i had a conversation with a couple of guys from Pretoria while being in your corner of the world lately.
Those Afrikaner always have faces that look like exposed to nuclear radiation. Nice lingo, but if you try to concentrate you haven't got a clue what they are saying.
People in some countryside areas overhere talk very similar. Sort of like German and Swiss.
now i wonder how much difference there may be between
afrikaner n' dutch
http://www.mfbfreaks.nl/images/algemeen/544.jpg
afrikaner n' dutch
TOMTT
--- i really like the way philips sound---
I do too. I used to like tweeter AD0160T very much and still have a pair working. Not sure, but I think the first Peter Snell's speakers had a Philips midrange.
~~~~~~ Forr
~~~~~~ Forr
The 2 active motional feedback Philips loudspeakers were really good. At the time of introduction i considered buying the larger model, but refrained because of expecting bad resale value. Secondhand prices did dive later, and i got me a set for a lot less.
Wish i hadn't sold them to a friend, they've become collectors items.
A relative of mine who worked at the Philips lab also confirmed that they developed great stuff, but never figured out how to proper market it. I still have one of the first CD-player model, a pre-series item before it went on sale.
Based on the number of Afrikaner i've met in 25 years, more resemblance than differences. Not just the language. I feel very much at home among people from Pretoria.
I assume the problem with Philips is that they have veeeeeeeeeeeery clever R&D staff but the products that arrive on the market are "developed" by the financial people.
Charles
544
I have a pair of mfb 544 speakers.
The Philips tweeters or not that good, they sound a bit edgy or sharp. I suppose because of the material the conus is made of.
You can upgrade those 544's nicely with a cheap peerless tweeter and of course you can change to quality capacitors in the passive x-over between mid and high.
Re: 544
Here , you have the schematic of the Philips MFB speakers...😉
http://www.diyaudio.com/forums/showthread.php?s=&threadid=5886&perpage=10&pagenumber=2
Jaap said:I have a pair of mfb 544 speakers.
Re: 544
i suspect the amps are not as good as the tweeters,
for the higher hz, any way.
edgy and/or sharp sounds like electrolytic cap distortion.
It is always wize to change electrolytic caps in old gear. But I used those tweeters also in passive loudspeakers and they have that little edge. It has for shure to do with the material of the tweeter. After I changed the tweeters in the MFB544 for Peerless 811815 without doing anything else it sounded a lot better and less nervous.
Re: Re: 544
Originally posted
or-
solid state
Jaap,
what crossover cap(s) did you use?
made of?...
Originally posted
or-
solid state
Jaap,
made of?...
to be honest
I don't remember because it is long ago.
But I spoke other people who had the same opinion about the 160 tweeter. I still have a bunch of these things lying around. That peerless thingie sounds really better !
Re: I think so
There is also the AD 140 T4/8 , from the same era .
The only diference , quoting my old trusty Philips components and materials book, is the resonance frequency :
- AD160 - 1 KHz
- AD140 - 1,2 Khz
Jaap said:I have never seen a lower number
- AD160 - 1 KHz
- AD140 - 1,2 Khz
- Full Range
- Anyone heard Philips AD50600/SQ8?
