Hello all,
I have searched the web to the point of exhaustion for Thiele-Small parameters on a PW1588-US. No sign of them anywhere. Seems like all of the retailers think the only important information concerning a driver is its magnet size and wattage.
I emailed Pyramid several days ago...still no reply.
If anyone has this information or knows where in this universe it may exist, I would sincerely appreciate it if you would pass it along. 😉
Thanks in advance!
pdq
Thanks in advance!
pdq
reply
Yep i've finally found the TS parameters on this driver for you.
Pyramid PW1588-US
x max 4.6mm
QMS 13.82
QTS .37
QES .38
VAS 16.23 cu . ft
FS 23 hz
SPL 1w/1m 90 db
2.5 inch voice coil on Kapton former
frequency response 20hz-3khz
Pyramid PW1588-US
x max 4.6mm
QMS 13.82
QTS .37
QES .38
VAS 16.23 cu . ft
FS 23 hz
SPL 1w/1m 90 db
Thanks Bull.
I had pretty much given up all hope for finding any info on this driver. The parameters you listed appear to be identical to the PW1554-US, which is what I ended up ordering two days ago.
The 1554 parameters can be found at www.partsexpress.com in the Pyramid section. Other than the power rating, the 1554 must be the 4 ohm equivalent to the 1588, no?
Anyway I sincerely appreciate your efforts in locating this info for me. If for nothing else, I use it for future reference.
pdq
pdq
