Hi everyone,
I just bought 2 JBL6260 amps to power my subs. Problem is one is only working on 1 channel, and both look like somebodies had a 'fiddle' with the wiring to the switch, and around the fuses.
Even the working one has a lead from the trans wrapped up with tape, not connected to anything.
Does anyone have a schematic so I can try and work out where this wire is meant to go ? After that I can try and get the other channel working.
Cheers
Rob
Cheers
Rob
http://www.jblproservice.com/pdf/Vintage JBL-UREI Electronics/JBL-6230 & 6260manual.pdf
Scroll down to page 31
/Hugo 🙂
/Hugo 🙂
Fantastic🙂
I got no results from the search engines, and only found 1 pdf from jbl which listed the product no. against what the product is. I've just got to hope my flaky connection stays up long enough to download the 3Mb file.....
Thankyou,
Rob
Thankyou,
Rob
hi netlist,
how about cerwin-vega? do you have the links simmilar to that of jbl's?
thanks in advance....
JBL has a well hidden but good documented archive. It's a pain to find it on they're site.joan2 said:
What do you want from C-V?
/Hugo
hi netlist,
i am interested in their power amps, i saw one, a 250 wattter, i lost the model number, but it used 2sa747/2sc1117 power trannies in the ouitput....
thanks
thanks
