Anyone has the Software for DAC Evaluation boards from BurrBrown
Hi there!
I need a Program for DAC configuration to set the internal registers (like Attenuation, Input mode, ...) as it is bundled with the evaluations boards. As i´am not an genius in programming it would take me some time to write a program with an µC... So it´s easies if I have a running program or source code as a starting point to adapt it to the DAC´s I own. currently I have an PCM1738 that needs configuration on startup, otherwise -> no function....
The best would be if anyone has a code for an Atmel AVR, I´m a little bit familiar to them and then the possibilities would be great!
thanks in this way...
