I have been searching, and not found anyone who has, so just wondering if anyone knows if they are breakdown-able. I just picked up a new one from egay for $117+$8 shipping. So hopefully it will end up being a good deal. Anyone with some info???
Got it today, and broke it down in about 10 minutes. No fcc problems, mostly long wires actually. Great price for what i got. $126
you're really really lucky.
i went through 4 lcd's (and i'm still waiting for one that is finally diy friendly)
what sucks is phillips makes a **** load of lcd's and it has the worst FFC problem.....
samnsung synmaster's are great but ironically they use a NASA quality foil adhesive that is so strong that it usually tears the delicate flappy circuits on the side of the lcd..
so you got super lucky man.
I don't, I already have it set up on the board. I did remove the anti glare. I am still pondering taking off a second side, which has a reflective side. I am not sure if it will make everything white out, or make it work better. I will keep you updated on it. I do know that the lines are long enough to work with, but there is a board that is connected to the lcd. That one, I have mounted up against a L shaped board, so there is no movement. That one has fcc cables all the way across, so you don't want to mess that one up. It folds out nicely, but just do it once, because repeated time will surely break one. I am hoping to have it up and working in the next week or two.
