Any VOYD gurus out there ??
Hi - I have an lovely old Voyd turntable (circa 1987) with split-phase PSU. This is the one with the large stainless steel on/off switch and the brass plaque on the back saying 'designed by Phillip Voyd". This has been in my attic for many years. I would like to try and resurrect it !
The main prob is lack of power cable between PSU and deck. This appears to be a 6-pin DIN cable - I have been looking around on web and can't find one that looks right. Is there a Voyd expert out there that knows what I mean - is it wired pin-to-pin. THe Helius Orion arm looks as if it may need replacing - how does a SME arm fare on this deck. Is 2 belts better than one ??
I suppose the final question should be - is it worth taking the time and expense to restore this to its former glory or can I get something better and less hassle ?????
If it is the one I remember,with the inverted bearing(I think) and acrylic platter like a Pink Triangle,then you have a great turntable there.It was regarded as one of the very best in its time,on a par with Pink,Linn etc.....The Orion was a great arm too.They were a very good match with Empire/Benz MC's.IMO it is worth to restore it.
As for 6-pin DIN ,have a look at FARNELL,they have many in their catalog.
