Any simple DIY music server based on a Pi3?
Hello,
at this moment in time I am using an old MacMini 2010 which streams lossless music to a Beresford Caiman SEG DAC, it is ok, I can run it headless through Audirvana and I does pretty well, the software is not the simplest and most comfy to create playlists etc but it does fine, what I miss is web radio and I'd also like to use the Raspberry Pi3+ I used to run Volumio with, I didn't like to have the board flying around the desk, another AC adapter and too many cables so I am wondering if there is some DIY project which fits in a single box a Pi, it's power supply and, eventually, a DAC which might be as good or better than the MacMini otherwise I'd leave the world as it is and just miss web radios which are nice to discover new music.
Grazie
