I'm curious if anyone knows what Hypex is doing for Ncore 2.0? Seems they set quite a high bar for themselves I am would love to know how they plan on topping it.
Compare the typical speaker distortion to NCore THD / IM / noise, and you ll come to the conclusion there is not much that they can do to improve THE WHOLE SYSTEM, as the speaker is always the weakest part. Yesterday I did some 15Hz cone movement test on an 18 inch bass reflex woofer 18NLW9400 (not a cheap part, but a pro woofer) to find out if there is anything scratching / rasping after the weekends DnB / dubstep session. The woofer is ok, no voice coil touching the magnet sound, but: you can clearly hear the speaker is screaming 45Hz, 75 Hz, 105Hz, while the 15 Hz is inaudible / not reproducible by the BR cabinet. Would not make a tiny bit on difference in sound if the amp had 0.0001% THD or 2% - for sure!!
