Another SoundEasy problem - Error message "An invalid paramter was passed to a system
Hi all,
With all of the issues I had with MLS measurement I must have messed something up on my system. This is only a problem on the Win7 notebook, not the XP desktop.
Now when I run the CRO on either the internal RealTek sound card or on the Tascam US-322 and I press the Run in the Test Waveform Generator I get the following SoundEasy error "Invalid parameter was passed to a system function". I have reloaded SE. I can't do a system restore because in the process of working on the other problem I disables system restore so I don't have any restore points back to when it worked.
Anyone have any ideas?
Thank you,
Jim
I got it fixed. It turns out on my systems, Win7 64 and 32 bit, that the preferences cannot be set to 16 bit. Once I changed it to 24 bit everything worked fine. Although this is not an issue on an XP based system, just Win7.
Thank you for your attention,
Jim
