Hi again
Some poeple may ask why I tend to show bizzare and stupid topologies.
Are you fed up??
I'm just bored with always the same topologies again and again...
What I do is (pathetic?) trial to find some new ways
so I show you thoughts that came through my mind...
patience please....
This one uses 3 integrated OPAMPS and 3 short feedbackloops.
Values aren't crucial - take care to topology
Looking forward to comments
(schematic attached)
Are you fed up??
patience please....
Why don't you get a Simulator program? LT Spice is free, from Linear Technology website. I haven't used that one, but I have a simulator. If I have an idea, I can draw it out, run the simulator, and see what happens. It really is a very good way of trying things out. You don't get the smoke that you get with a breadboard layout, and it will display all the operating conditions for you without the need for measurements. You would easily be able to try any topology you can think of.😀
Hi darkfenriz
Your amp is a transconductance amplifier ... output will be a CCS and it will have zero damping to the speaker.
hi johnnyx
could you link this page...
maybe i should simulate things first but a simulator cannot tell me what is actually wrong and what to change
hi Tube_Dude
I don't get your point
what is CCS ?
thanks guys
hi Tube_Dude
what is CCS ?
thanks guys
darkfenriz said:
hi Tube_Dude
what is CCS ?
Is a Constant Current Source...that mean that it will suplly the some current independent of the impedance of the load.
In simple terms your amp will have a output impedance of MOhms.
For to make your amp a normal voltage amp you must take the feedback from the output...
DEAR Tube_Dude
I thought that feedback loops taken from sources to the -input of opamps will do...
when one mosfet is open and the second closed there's huge current through the speaker and thus through the dren resistor..
much confusion....
much confusion....
darkfenriz said:DEAR Tube_Dude
much confusion....
Yes ...much confusion 🙂
With your feedback schema you are sensing the current through the load...then making a current amplifier.
There are a couple of threads about driving a 'speaker with a current amplifier, there are some advantages, but I don't think that you intended to design such a thing.
What about the crossover region between positive and negative output currents? would it give high crossover distortion?
I think a simulator would tell you a lot, if you split the design into sections and simulated each section independantly, you would see what each section does, with all the operating conditions, and then you would have a good idea how the whole thing would work.
- Another out of this world topology
