Another 4080 amp
I repair the output and power supply sections.Amp powers up and plays good audio but I can hear some squealing noise coming from the transformer .
Twisting the transformers doesn’t stop the noise.PS FETs on one side of the board gets warm while the other side stays cool.Drive signal look ok but it looks like some frequency interference on the side that is getting warm.
many suggestions?
10v/dv 10/us
Frequency interference?
How does the drive from one side compare to the drive on the other side? Look at the signal on the gate leg of every PS FET.
When you display the waveform, you want it to use bout 3/4 of the waveform (from ground up for this waveform) and to show about 3 complete cycles.
Is this displaying 2 channels or is it a problem with the triggering of the scope?
Did you try decreasing the vertical amplifier setting on the scope and adjusting the trigger level to get a lock on the waveform?
The two transformers are getting the same drive signal so I can't see that being the cause of one making noise, especially if the drive on the gates of the FETs is identical.
If you squeeze the windings round various parts of the transformer, does the noise change?
Drive signal on both sides look the same.
Only one channel is displaying on the scope in the pic ,what you seeing is another wave coming in and out according to the noise coming from the transformer .
There is only one wave; it looks like a problem with scope triggering.
Try increasing the display level and play with triggering (slope, level, pos slope, neg slope, or try to find another stable waveform with another scope channel and trigger on that channel.
First and foremost you want a nice stable display.
Jan
Jan
The square wave is stable.The pic I posted is what it looks like when the transformer start making noise
