ANK L3 Phono Amp kit assembled top quality parts
ANK L3 Phono amp. Assembled and complete minus the 2 power supply tubes. ECL82 and 6X5. I am including a 6DJ8 and a 12AX7. I added up the price for the parts just the big parts are as follows:
272BX Trafo - 105
Choke - 67
Triad trafo - 20
Big white Mundorf EVO cap - 77
Small EVO caps - 35 each *2
Audio Note caps - 58 each *2
Rel Caps - 24 total
Just those parts alone are like $470. Also all parts came from either Parts Connexion or Mouser. The circuit boards are not ANK brand boards but they are well made. This unit works great and is silent as they come. I lost the power supply tubes or I would include them. I have a moving coil cartridge and this did not have enough gain for it. It is in tested but unused condition. I am asking $300 you pay shipping. I live in Corvallis Oregon in case anyone is local. I used all Cardas solder. The wires on the boards between the sockets are supposed to be there. Its not a "fixit".
I got to say that your soldering is first rate. I don't mention crappy soldering to people, because I just figure that is the best that they can do with shaky hands or the wrong equipment. In your case, the solder runs through the board as it should.... And of course this sale is 'you get what you see' sort of thing. Nothing wrong with the price at all, it is just that I am not in the market for a phono. This product is one that I would have built in a heart beat had it not been for the fact that I had a Glass Ware phono project instead, and these normally are way above my budget. I am just saying that I hope that people out there are paying attention to an opportunity like this one.
I did notice that the one 13.8? AC input that was not hooked up because you had to take this apart at some point I guess. It looks black and I am sure that it very likely the flux from the solder remaining. Can you confirm?
Thank you for pointing that out. It requires one more transformer shown here that I am throwing into the deal for no added cost. I did not have documentation when i built this and I had to change a few values in the heater supplies to get 6.3 out of both of them. So yes it was disassembled once.
