I'm thinking about a multi-segment ESL that would approximate a quarter of a cylinder and fit well in the corners of a room. I'm worried about the "venitian blind effect" (variation in the high frequencies as you move your head horizontally while listening to the speakers). My quick calculations suggest the effect wouldn't be too bad if each ESL panel were 4" wide, and angled by 10 degrees relative to its neighboring panels. Can anyone tell me if I'm way off base?
I came up with 10 degrees by looking for the angle at which the output from a 4" wide panel, radiating a 15 KHz tone, would drop to one half of its on-axis output. I got something like 11 degrees, which I'm rounding down to 10 degrees. The 4" panel width comes from my experience with flat-panel ESL's using 1/16" diaphragm-to-stator spacing. I figure I'd need nine or ten such panels to form the quarter-cylinder. I'll deal with the large capacitance issue later...
I know the angled segments idea isn't new, but I don't have personal experience with it. Can anyone offer any advice or insights?
Thanks in advance.
Few
Thanks in advance.
Few
I built one like that
several years ago and used 6 (or was it 8?- probably 6) vertical strips per channel. If I recall correctly (I have then in a box somewhere) they were about 24" high and 4" wide. I believe I used an angle of about 170 degrees between adjacent strips. The insulators were made of 1/16" fiberglass PCB. THAT was a pain to cut!
I mounted the strips on two pieces of aluminum L stock that had been notched and bent to the desired angle. It was a real easy to mount them that way compared to trying to cut wood at several small angles. The two aluminum pieces were spaced vertically by a couple side pieces of wood.
I did not find any venetian blind effect, but even if it were there, you would not notice it unless you were moving around in front of the speakers. It will be a bigger problem near-field than far out from the speaker.
While sort-of cylindrical configuration worked for dispersing the high frequencies over a wider area (only a little wider area), I ultimately decided I liked the sound of flat panel ESLs better. The imaging of flat panels is really good. As soon as you disperse the highs around the room you have problems controlling reflections and that somewhat reduces the sharpness of the imaging.
Martin Logan builds ESLs with curved panels. I used to think it was for high frequency dispersion, but the reality is that the high frequency dispersion isn't aided much by gently curving the panels. The curve is there to make the assembly rigid. I found that out when I built a pair of 2' x 4' flat panel ESLs just to see if I could make them that size. While they worked OK, they had one big problem. 2'x4' perforated steel is heavy. When you suspend two sheets by their edges n an ESL, it acts like a drum. If you bang the frame of one of those speakers with your hand, the driver wobbles back and forth for quite a while. I consider those speakers a failure but a lesson learned.
I_F
I_F
Thanks I_F, that helps. I like your method of mounting the angled panels.
I too have built a large flat panel ESL system. There are many features I like, but I do find I often listen off-axis when I'm doing something other than just listening--or when several people are watching a movie. Widening the listening area is one of my main motivations for thinking about the segmented approach.
Another motivation is that I'm interested in testing the idea that if you mount a quarter cylinder in a corner there won't be any early reflections from room walls (at least to a first approximation). I really like the imaging associated with mini-monitors mounted away from the walls but, at least from the (naive?) theoretical point of view, it seems true corner mounting might be an alternative solution to the early reflections problem. Trying to do this with dynamic drivers would be difficult because you can rarely get the radiating surface of the speaker close enough to the room boundaries, at least at high frequencies. It seems like it would be a cinch with ESL panels. It would also reduce the diffraction problem evident in so many conventional speakers.
I'd be interested to hear about the results of other people's efforts to corner-mount or even wall-mount drivers---ESL or otherwise. Is there a flaw in my reasoning?
Few
Few
Few,
I think your plans are quite worthwhile. If you consider the placement of a quarter-cylinder radiator tight into the room corners from a reflected-image perspective, you can imagine an effective full cylinder radiator whose center line is the corner of the room. Therefore, reflections from either adjacent wall will behave the same as emissions from the rest of a virtual cylinder radiator, three quarters of which is “behind the walls”. If you make the speaker reach from floor to ceiling, you will even pick up image reflections from the floor and ceiling which will extend the line source ad infinitum. Symmetry is a wonderful tool, isn’t it?
Imaging should be excellent since you will be listening to what appears to be an infinitely small line source at the corner. This is so because the cylinder replicates the expanding wave front a millisecond a two after emission from a line source. The only concern I would have has to do with controlling the back wave, which is now trapped in the corner. I would want to fill the corner with absorbent material whose impedance increases (thicker material) as you approach the corner so as to absorb the back wave. Otherwise if the radius of the cylinder is say, 1 foot, you will have a reflected impulse coming back through the drivers at around 2 milliseconds after the first impulse. But this ought to be very controllable.
As to the “picket fence” effect, I think you should not worry too much. The effect is best described as lobing, not as a “picket fence” response anyway. There shouldn’t be any deep nulls. Any driver-to-driver angle less than 20 degrees (or stated as greater than 160 degrees) ought to show very smooth response. Only at the top of the audio range will there be some gentle lobing, but in any case this ought to be less severe that the sinx/x lobing from a planar driver!
Let us know how it works out!
Do you not worry that the backwave reflected out from the corner will pass through the relatively transparent diaphragm and cause some severe interference effects?
Thanks for the responses and encouragement. Brian, your description of the images forming a complete cylinder whose center is at the corner of the room is exactly what I had in mind. I also agree with all the comments about the reflections from the walls, but am (for the moment) optimistic about the possibility of absorbing most of them. I figure I'd need a two foot radius quarter cylinder, and that would provide quite a bit of room for sound absorbing material behind the panels. I'd be limiting the ESL to frequencies that are strongly absorbed by acoustic foam or wool because I'd plan on crossing over to dynamic drivers around 400-500 Hz anyway.
I remain intrigued! Thanks again for the helpful ideas.
Few
Few
SY,
Well yes, that's why I mention the absorptive material. Remember that regular cone drivers in a box also suffer from this reflection effect, although the transmissibility of cones will be lower. With a large quarter cylinder ESL as “Few” intends, it should be possible to put enough absorptive material in the enclosed area to drop the intensity of the round-trip reflection to acceptable levels. I think it should be graded material, with the highest impedance at the corner due to pressure concentration there, but that’s probably not critical. With the many other advantages of this kind of scheme, it would seem a shame to abandon it due to worries about this problem. And don’t forget that the other frontal “reflections” actually build the desired wave front rather than add unwanted delayed response, so that this kind of scheme ought to suffer from far fewer room interaction effects compared to regular speakers, even with the one back wave reflection to contend with. Just MHO.
The back wave would certainly reflect off the walls and come back through the speakers with some delay. It would be hard to predict what that would do to the sound because the distances and angles between the walls and each driver strip will vary. At high frequencies it may behave like a comb filter. At lower frequencies, maybe just some selective reinforcement/cancellation. I suspect that like almost all other ESL installations, it would be best to absorb the backwave.
The nice thing is it is pretty easy to try it out, and then we'll know for sure how it behaves. If it doesn't work out too well, the panels are still useable to make a flat speaker...
I_F
I_F
Actually it’s not that hard to predict the results of the reflections in this case – if we assume that the drivers are arrayed in a perfect quarter circle. This assumption applies for all but the highest frequencies where chord and arc differ a bit, but then those same high frequencies are very easily absorbed anyway.
I’ve been working on a full-range ESL cylindrical speaker intended for use in a large room far away from walls, and I’ve had to consider most of this already.
Start by imagining a perfectly cylindrical speaker. There are no nearby surfaces. You’re looking down into it, so that you see a circle in cross section. Now imagine driving this speaker with a single positive-going impulse (which represents all frequencies, of course). Now you’d see a positive pressure spike growing outward from the speaker in an ever-expanding circle, concentric with the speaker, heading towards the listener who is about to hear the closest approximation to an impulse he’s probably ever heard. Inside the speaker, you’d see an ever shrinking circle moving toward the center, but with negative pressure compared to the outbound pressure front. When this circle collapses into a point in the center for an instant, the volume has been traded for pressure and we have a point source of very high (negative) pressure (really a line source in the Z-axis, but viewed on end). Now the pressure point becomes a source for an ever expanding circle which heads back toward the drivers, still in inverse polarity compared to the outbound wave. When this circle hits the driver circle, some energy will be reflected back toward the center again for another round trip, but most will pass through to follow the main wave front. If the speaker has a radius of r, then the negative pressure ring will follow the first by the time corresponding to 2r. The listener will observe a nice positive impulse followed at 2r-time by a weaker negative-going, smeared impulse (and then further reflections every 2r times). This will result in the familiar comb filter response at very predictable periodic frequency multiples.
Now if we consider the driver transmissibility (to waves passing through) as a function of frequency and consider viscosity, resistive losses and the effects of grills etc, the reflection will be corrupted, but surely it will be at least low-pass filtered in some way. I’ve done simulations of these effects and have gotten good correlation with reality. These effects will smear the reflected impulse shape in time and reduce its total energy. Now, let’s add some absorptive material inside the cylinder. If we can achieve at least 20 dB of attenuation across the 2r round trip, we would see just 1.7dB ripple instead of the severe comb filter peaks and valleys without attenuation (if driver transmissibility were as bad as to be unity). If we could achieve 40dB of 2r attenuation (at higher frequencies perhaps), the ripple would be 0.17 dB – not too bad!
Now take a quarter section and push it tight into the corner. The walls prevent flow normal to their planes, but allow flow in the shear direction, which is the same as predicted by symmetry for a whole cylinder without walls. Shades of Klipsch and Allison! Said crudely, if any one driver tries to push air “sideways” into its neighbor’s pie section, the neighbor driver pushes back equally hard and no air can flow tangentially or circumferentially – it all moves radially, away from the center (or towards it). This exactly matches the boundary condition imposed by the walls in a quarter section – or, for that matter in a half cylinder section pushed up against a long wall, far from any corner. Now fill that quarter cylinder with a pie-shaped chunk of the same absorber from the cylinder, and you’ve got the same reduction in ripple due to reflections. Ain’t symmetry grand?
I’ll say this again: If anyone thinks that these reflections don’t plague other kinds of speakers, think again. Most other speakers in boxes have all kinds of irregular and frequency-dependent wave fronts inside, much of which do pass through the cone to color the tone. And point source and planar speakers just don’t make constructive use of wall reflections as does a cylinder section. This is why Roger West sells his SALLIE back wave absorber for his magnificent speakers, but I digress. Planars are far from wavelength independent, because each frequency is treated differently in comparison with speaker dimensions – Fourier transforms of apertures and all that. And then there’s dipole cancellation. Cylinders and cylinder sections against walls can circumvent much of this wavelength dependence, and that means flat, phase coherent sound – which is our goal - if we just consume the back wave.
Sorry for the long post…
Brian, a very nice explanation. Thanks.
Reflection from internal surfaces does indeed happen with cone drivers, but the cones are much less acoustically transparent than film diaphragms. Nonetheless, the TLs I've built have a slant board behind the woofer just for this reason. It doesn't eliminate the effect, but it does reduce it considerably.
Who besides Radio Shack and Janszen/KLH has ever done this? This statement only scratches the surface of your delusions. I'm intrigued!I suspect that like almost all other ESL installations, it would be best to absorb the backwave.
The two of you seem earnest in your analysis and even seem to have had real world exposure to ESLs, but I think you have whipped each other into a frenzy in this search for the holy grail in ESL design: "Riddance of that pesky backwave."
But I admire anyone who likes ESLs, and I like even more those who would actually build their own. So forgive me for saying this, but I think you're going to end up with a pair of giant ESL corner tweeters. The back pressure in the corners won't allow any bass. I think even a brief internet search for ESL theory will uncover this. I'm sorry I can't back this up with any concrete proof or even point you in the right direction right now, but I hope somebody much more insightful can put you straight.
But I think you should try it anyway. Just leave yourself the option to move the arrays out into the room where you can really let the dipole dispersion pattern make the ESL show its strengths. After ESLs you will never go back to the muffle of regular speakers.
You like quotations? "Those who cannot learn from history are doomed to repeat it."
I think the problem is not whether it would be best to absorb the rear wave, rather the difficulty in doing so over a wide bandwidth. As far as I know, neither RS nor Janszen managed to do it either, except at the highest frequencies.
This is why I prefer flat panels. The rear wave (at least at the higher frequencies) can be controlled by directing it away from the listener through careful positioning of the speakers and listener within the listening space. As soon as you start spraying the audio all over the place, you lose the ability to control it.
As I am always seeking to improve and expand my limited knowledge, may I be so honored as to have a true guru, such as yourself, elighten me as to the nature of my other delusions to which you alluded?
Humbly yours,
I_F
Humbly yours,
I_F
Peter Walker (see 1955 Wireless World articles), and Harold Beveridge. Granted few others have tried. I'm not saying this is easy, cheap or even practical, but when have those limitations stopped us DIYers from pursuing perfection?Who besides Radio Shack and Janszen/KLH has ever done this?
Huh? The back pressure in closed box cone woofers doesn't allow any bass? If you had said that the resonant frequency of the diaphragm is increased by the enclosure, I'd have known you understood. If you put any electrostatic panel into an enclosure, whether it’s a box, a corner (for a quarter cylinder), or a flat wall (for a half cylinder) or even a full cylinder as I’m doing, you can use Thiele-Small type analysis. Yes, you must control leaks or you’ll end up with a fourth-order vented cabinet (no thanks).Yes, even electrostatic panels have Fs, Qts, Vas, etc., although the values look pretty strange when you’re used to heavy cone drivers. But the point is that ESLs follow the same physics laws as cone speakers in enclosures, and those certainly can manage to make bass. Remember that the dipole cancellation is the most injurious to bass, and we have an opportunity to eliminate that problem (Quad lover that I am). Now I will tell you from experience that it is difficult to get low enough Fs and Q values for smooth deep bass, so these cylinder sections may be more readily feasible as “almost” full range speakers. But “just tweeters”, no. Worth the effort for almost full-range? Absolutely.I think you're going to end up with a pair of giant ESL corner tweeters. The back pressure in the corners won't allow any bass.
Read the thread again. Putting a quarter cylinder in a corner results in effectively no reflections from the side walls - due to symmetry. If it's floor-to-ceiling, the floor and ceiling effectively no longer add reflections (as in any line source). Only the back wall must be considered. Dispersion? Stand up, sit down, move left, move right, it doesn’t matter. The same wavefront is coming at you with almost ideal impulse response. Not so with dipoles or monopoles. Hard to comprehend, I know. Look in an acoustics text about reflective imaging for starters. Symmetry is the magic bullet.Just leave yourself the option to move the arrays out into the room where you can really let the dipole dispersion pattern make the ESL show its strengths.
I'm all ears.I hope somebody much more insightful can put you straight.
Agreed!After ESLs you will never go back to the muffle of regular speakers.
Well it does take some effort. The question is whether it's worth it or not. For the reasons I've already stated, I think it is. At mid- to higher frequencies where the constructive/destructive cancellation ripples could occur, absorption can be quite effective. The bigger the diameter, the lower the onset of ripple, but also more absorptive material is available in the larger space. Below these ripple frequencies the speaker behaves as a closed box enclosure amenable to Thiele-Small analysis, as I said earlier. At those frequencies absorption is only of secondary importance (just like in a regular woofer box). These are areas that I have been spending some time on.I think the problem is not whether it would be best to absorb the rear wave, rather the difficulty in doing so over a wide bandwidth.
I'm not sure who "the two of you" refers to, but as the initiator of this thread I'd like to point out that my original motivations for corner mounting a quarter cylinder were to eliminate the reflections of the front wave from the ESL off of the room boundaries and to minimize the dependence of the frequency response on the listener's position. Controlling the backwave was not proposed as a "holy grail"; it's just a necessary step toward achieving the primary goals.
As for the fundamental resonance, it's true that it will be affected by corner mounting, but that's not the same thing as restricting the panel to tweeter-duty. If diaphragm material that is more compliant than mylar is used, the free air resonance can be made quite low. Low enough so that the corner-mounting doesn't raise fs too high? I haven't yet done the tests or calculations to find out. However, since my stated goal was to have the ESL operate from a several hundred Hz on up, I think things look promising. My biggest problem now is that I don't yet have the corners necessary to test the idea!
It was unfair of me to "attack" you, especially without backing it up with any reasoning, and I'm relieved that I have merely tested your resolve.
But I don't like the analogy you make with sound and light by suggesting that placing the quarter cylinder in the corner will yield a symmetric wave front, as if it were an image in a corner mirror. It seems the sound will be smeared by the early wall reflections, which is what you want to avoid. In fact you now have something like a lens or horn formed by the corner.
And once again I'm sorry I can't give you the actual patent number or anything, but didn't Walker's physics show that ESLs are analyzed completely differently from dynamic drivers, and can't be thought of as being comprised of a piston, motor, springs, and dampers (as S-T does)? Isn't the whole beauty of the ESL in that it comprises an effectively mass less, tensioned diaphragm controlled by (coupled to) the air around it? Where do you get an Fs without mass? The symmetry you seek is across the diaphragm, not up against the wall. I just think you've overlooked something fundamental to ESL analysis (and possibly sound in general)...
I'd like to humbly and cowardly exit from this discussion now, as I hear my mommy calling.
Sorry to hear you're exiting, Tosh. I'll offer these comments anyway.
There is very definitely a fundamental panel resonance, and it generally has a pretty impressive Q. You can just tap an undamped ESL panel with your finger and hear the resonance sing out (it's around 100 Hz in my current system). If you increase the diaphragm tension the resonance frequency goes up, as you'd expect on the basis of a mass-and-spring model. The mass is the combined mass of the diaphragm and the air in its immediate vicinity; the spring comes from the compliance of the diaphragm material and the compliance of the diaphragm's air load. The latter is the origin of the "no bass" concerns you voiced previously.
I can't tell if the disagreement about the wall reflections stems from confusion about the front and back waves or something else. The following comments are all restricted to the front wave---the wave that travels directly from the speaker to the listener. I offer them as an alternative to the symmetry arguments helpfully supplied by Brian Beck. They amount to another (perhaps less elegant) way to say the same thing. For simplicity I'll assume an infinitely tall quarter cylinder (or one that reaches floor and ceiling).
The early wall reflections are controlled in the proposed configuration because the wavefronts are always moving parallel to the walls where the wave and walls meet. The key point is that in order to generate a reflection some component of the wave's propagation would have to be perpendicular to the wall. If the previously described quarter cylinder shaped speaker is placed in a corner, and the speaker creates an impulse, the wavefront leaves the front of the speaker as an ever-growing quarter cylinder. If you examine the direction of the wavefront's propagation where the wave is near either of the two walls forming the corner, you find the wave is always moving parallel to the wall's surface. With no component to the wave's propagation perpendicular to the wall there's no reflection.
A complication arises if there's an opening in one of the walls--say an open doorway. In that case the cylindrical wavefront will experience a sudden change in acoustic impedance and the edges of the door opening will act as secondary sound sources. This is all just an overgrown version of the well known diffraction effects encountered when the sound from dynamic tweeters reaches a sharp baffle edge in a conventional speaker. I think it would be desirable to keep such openings---or protrusions from the walls (ie bookshelves)---far removed from the speakers.
Few
Few
Excellent way to explain the concept, Few. I hope you will keep us posted (literally) as your corner speaker comes to life.
Can you guess what would be the T&S parameter of an average ESL: (like quad 63 or accoustat model 3)
vas
qts
qms
qes
mms
fs
bl
martin
- Planars & Exotics
- angles for segmented ESL?
