"Ande" brand drivers
Belfield music sells the Celestion range and does free shipping too, not bad value
https://www.belfieldmusic.com.au/celestion-t5602-ftr18-4080hdx-ferrite-magnet-aluminium-chassis-driver-speaker-18-inch-1000w-8ohm.html
23 Kg for an 18" driver is crazy heavy, the Ferrite Celestion rated at 1000W is half that, Neodymium would be much lighter still.
Something to think about if you have to move them.
Very difficult to find much information on the Ande drivers and frequency response can vary wildly with these sort of PA woofers.
I use a faital pro 12FH520 in my midbass horn and i agree they make nice units
Have you posted pix / plans / measurements of this midbass horn anywhere?
Given that the big name brands are really expensive to get in Oz
In situations were size is not a limit (e.g. infinite baffle, slot loaded open baffle), a large array of very cheap woofers seems like a good option.
These are stupidly cheap:
https://djcity.com.au/product/skyte...riteo&utm_medium=cpc&utm_campaign=lowerfunnel
Hi Hollowboy, its just a prototype at the moment. Short conical horn with 800 x 400 mouth. Good to about 200hz crossover. Pics below, cheers
