ZVN4306GTA has been work horse for my Pocket Class A. Sounds great. It has a complemtary P channel.
If you don’t mind TO220, IRF610 and 9610 are good. Recently I started using Fairchild FQP32N20C. They are excellent as well. Probably lower distortion than IRF’s.
If cost no object, some new (old stock) Toshiba 2SK2013 and 2SJ313’s are excellent. Beware of fakes.
Which part is its complement?
I meant to say there are P channel variants - but maybe not complementary. ZVP4424G for example can do -240v and 0.5amp.
Sure there are books and the ones by Self and Cordel are excellent books on amplifiers in general. HP amps are just a subset of lower power lower noise amps. Because they are lower power and demand the highest performance in terms of noise and distortion - Class A is the perfect way to go. A good way to learn is to get LTSpice and start with a current design that’s proven. Start simple - like the 2 transistor SE Class A pocket amp that I made. Ask questions in the forum and work through the problems. You will get both theory and practical hands on experience as you try to design your own amp on the forum. It’s better than a book trust me.
Thanks man .
I will surely go with your method . Specially diyaudio is friendly community. You also are so awesome.
Any way which diode bridge is best for 15v supply? Which toroidal transformer I should choose to get 15-0-15? I am so confused. Is their any modern alternative to 7815 and 7915 regulator?
If you use a transformer supply, a good way is Class A operation.
But if you will use battery supply, then you should not use Class A.
For the batteries will be empty in a short time.
Most opamps draws little current,
so they are good choice for battery operation.
For a headphone amp, you will be happy with a 50VA toroidal transformer. 7815:7915 in TO220 are fine for getting started. You can get TI TPS7Axxx regulators integrated into a small TO220 78xx/79xx style package from eBay for $10 to $15. They are 4uV rms for positive and 14uV rms for negative.
You can also avoid trafo and dangerous AC mains by getting a DC-DC converter and use 12v wall wart to power.
That’s what I am doing in latest amp - and the PSU is quiet like a battery. It’s more expensive than trafo/bridge/caps/7815-7915 option though.
See here for details on the new DC-DC psu - gives up to 310mA of +/-18v from 12v wall wart.
Simple High Performance DC Coupled Class A HPA with sub PPM THD
Here are the TPS7Axxxx regulators
Here is the 11W dual rail PSU:
Here is measured noise performance. Note lack of any mains AC peaks or harmonics:
But to get started, the trafo linear supply is a good start. Lower cost too. Just be careful with AC mains voltages and proper earth grounding.
Btw, qnty 6 x 6v sealed lead acid batteries (+/-18Vdc) will run a class A HPA for a long time (20hrs or more depending on bias current).
TPS7Axxxx
This fet look like interesting replacement for bf862.
I got 50 bf862 from eBay . They turned out to be fake one.
I thought my circuit was wrong so they got burned but when I used on a car radio with bf862 , it didn't work .
I am scammed!
Bf861 in verge of EOL
Why NXP semiconductors discontinue such a great product.
http://www.onsemi.com/pub/Collateral/ENA1965-D.PDF
I am scammed!
TPS7A are low dropout voltage regulators not JFETs. When buying BF862 on eBay make sure vendor quotes the markings. Marking “2AW” is the usual BF862. They are too small and cheap to fake. They probably sold you wrong one or claimed it was BF862.
TPS7A I know are regulator I bought completely assembled PCB from eBay. StillI haven't tried them.TPS7A are low dropout voltage regulators not JFETs. When buying BF862 on eBay make sure vendor quotes the markings. Marking “2AW” is the usual BF862. They are too small and cheap to fake. They probably sold you wrong one or claimed it was BF862.
I will try to find bf862 locally.
Why are rail splitter used by various cmoy builder? They can get ground from middle of two battery.
Rail splitter used on single 9v I think. +/-4.5v rails - but is not same as two +/-4.5v batteries.
The original Cmoy was one 9V battery.
Download and install it. Get a simulation posted from one of the threads you are interested in. There is even a how to thread for LTSpice in DIYA.
Thanks.Download and install it. Get a simulation posted from one of the threads you are interested in. There is even a how to thread for LTSpice in DIYA.
- Headphone Systems
- (and) low noise Power MOSFET
