Hi!
I have this DAC, AK4584:
http://www.asahi-kasei.co.jp/akm/en/product/ak4584/ak4584.html
I'm asking your opinion what to put to its LOUT & ROUT pins. There isn't nothing yet. 🙄
I'm thinking to use that with Corda HA-1 II Headphone amp and modified Sure Electronics Tripath TA2024 amp (http://www.diyaudio.com/forums/showthread.php?s=&threadid=112395)
Any ideas? Some kind of opamp circuit? What opamp to use? Dual AD843 or something else? I will appreciate all help.. Thanks! 🙂
-Mikko
-Mikko
That is A/D and D/A interface chip...
If you need differential to single end analog stage, one was discussed in detail in this thread:
http://www.diyaudio.com/forums/showthread.php?threadid=137976&perpage=25&pagenumber=5
Boky
Boky
Yeah, I'm thinking to use its ADC as a measure device with Eric Wallin's preamp 2 microphone preamp (green inputs). I don't know why there are capacitors in the picture because text says there are internal HiPassFilter that removes DC offset? So I don't have to put any caps to signal path?
Here is some schematics of that AK4584:
DZF in Zero Input Detect Pin (output) so I think it can be used to turn amp off when there isn't anything in the ROUT & LOUT. It says in the page 8 of the datasheet that DAC analog output is 3 Vpp (@5V VREF). So if I use opamp, I don't need too much gain?
I did some more searching (a little too much, I think) and there was op amps (which sounded promising) like LM4562, OPA627, AD843.. And then I found discrete opamps / discrete output stages. And then.. I'm now considering Lampizator.
So hard to decide what to do..
"Analog Outputs are single ended" .... you can feed them straight to the pre-amp with reasonably high input impedance. No need for any further gain neither.
The inputs can do without the capacitors.
Boky
Boky
