Hi ,
I can't find in my city one IC that i must use to make a echo microphone ... AN6550 i can't find it ..
Someone know a good substitue ?
THANKS!!!
THANKS!!!
The AN6550 is a dual operational with a phase compensation and low voltage operation mode ....the question is ...are u constricted by the low voltage usage mode ? or not .I found those ....surfing and as i see there are some goodies bonus ....slew rate and so on ....didn't checked the equivalence but this worths to be seen.
http://www.electronics-lab.com/forum/attachments/AN6557.pdf
http://www.alldatasheet.com/datasheet-pdf/view/PANASONIC/AN6551.html
Take care though tere are many parameters that can be modified...as i understand that u intent to use it in a microphone stage.
