Amphion Bases DIY project
Hi, I am going to be making a pair of Amphion Bases type stereo subs (photo attached), to use with my Amphion One15s, and would like to ask you folks some questions:
1. I am going to be using Seas 10" drivers and passive radiators, there are to options, one with two layers (L26ROY) and one with four layers (L26RO4Y)
Which one would you recommend for this application?
2. I will probably be using two Hypex Fusionamps plate amps, going to choose between FA251 and FA501.
Which would you choose? is 250 watts enough for a single 10" in a large box, working all day with the subs behind the desk? or should I go for 500 watts? won´t need lots of SPL
3. Regarding Fusionamp DSP crossover, I want to integrate the One15s and the subs with the crossovers, but be able to bypass the subs and use the One15s in full range mode.
Is this easy to do with the software? I think you can´t control both amps at the same time, so it would be cumbersome to change the usb cable when going full range?
That´s all for now, thanks everybody!
