I'm working on an amp and it has a 3 way switch for the crossover .
I cleaned the switch with contact cleaner but it doesn't help.
If i press on the switch i can get it to work like it should but if i let go of it then the right channel goes dead again.
Is there a way to fix this switch or do i have to replace it ?
If contact cleaner doesn't fix it, you'll probably have to replace it. Best of luck finding the replacement...
Tom
Tom
Sorry i didnt get back sooner been busy.
The amp is a kicker 550.1 I found a replacement switch for it out of a junk board.
