Amp, Stange temporary buzz, what is that?
Hi
This is my first post on tube forum. I have a Dynaco St-70 Serie 2 from SoundValves. This amp has 2 LED on the front pannel to adjust bias on each channel.
I had this strange problem yesterday.
On startup, in normal conditions, only one of the two LED light up and gradually, when tubes get hot, the second one slowly light up and get the same luminosity as the other. this take about 1 minute.
Yesterday, I turned on the amp, everything was fine, then after 30 sec, there was a strange noise, like a soft noise for a couple of seconds, and one of the LED went off. I waited and after 10-20 seconds, the amp went back to normal. the sound was OK. I repeated the startup procedure and it did the same thing.
What is that? is that dangerous for speakers? I thought the amp was going to blow. But it worked perfectly after that.
F
I've been waiting to see if someone posted, who had experience with this particular amp. Since no one has, I'll give some general guidance:
Try swapping the output valves (tubes) between the channels, and see if the other LED is affected instead. If so, then it's a valve problem.
Output valves are the least reliable components used in amps, so there is a good likelyhood that one is the cause. I believe they are the EL34's in this model. When you locate the faulty one, replace it's partner also.
From reading this I'm not convinced the tube(s) are at fault here.
Rather the softstart procedure seems to have a problem, if it's controlled by a cap charging then this may be faulty...or maybe a relay is on the blink...?
Cheers,😉
