Amp Help!
Amp to drive Kicker boxes.
Are the subs actually "Kicker" brand? If so, the enclosure will have much to do with the required power. If you choose a sealed enclosure which will play into the trunk, don't expect great bass. If you find a capable sub enclosure builder, ask him to design a bandpass enclosure with a partially external, square (so it won't whistle) port which exits from the top of the box. It can pass through a square cutout in the parcel shelf and deliver deep, tight, bass to the INSIDE of the car! P.
AHScomets87 said:
I got two 10" Kicker Comp VRs. Looking for an amp that will make them sound good. Any Ideas
It is more than just the amplifier. You need an enclosure suited to the woofers as well as an overall goal in mind to what you want them to do. Are you after SPL only, SQ only, or all-round utility?
speaker
