So when i put on Camaro-young jeezy the bass cuts out at the 3rd bass pitch (The high one) and my amp is left in protect mode. Any idea as to why this is happening? its done it on a few other songs too. could it be the way i have it tuned?
My guess is a nasty impedance spike at that frequency.
What driver(s) are you using and what load is the amp running at?
amp clipping?
sufficient headroom/underdriven speakers?
Many variables until the intricacies of your system are known.
amp clipping?
I have a 4 channel pyramid crystal PB1881x amp. 2 jvc 1000w 4ohm subs. and use a little more simple language if you need anything else, im not a pro at this. haha
Meh, if the subs were wired for 2 ohms, that wouldn't do the amp any favours.
If you just connect one sub, does the problem go away?
The best Pyramid amps are OK down to 4R in stereo, 8R in mono.
The lowest priced ones aren't worth buying.
Agreed , the amp I presume is seeing a 2ohm load, which I doubt it's rated for. In addition, it's more than likely producing 1/4-1/3 of it's advertised output, as has been my experience with these off brand amps (pyramid, legacy, boss, etc.)
Hopefully you didn't give up much coin for this stuff. Maybe scale back that hooch habit, and spend some more on amp/subs worth installing.
Got it all for free, just bought wires and a head unit. And all my money is goin for college.
The problem doesnt go away if only one is working, tried both.
Ill def have a better system when i have cash to spend. But whats a lest costly/good quality amp to power the subs posted above.
Just change the wiring so the subs are in series instead of parallel.
You'd lose some available power output, but it should make sure your amp doesn't shut down.
"The problem doesnt go away if only one is working, tried both."
Are you running the amp in 2ch or 4ch mode?
If running in 2ch one 4R sub is too low of a load.
Run the pair in series, or run one driver per channel in 4ch mode.
If i wire them in a series then it doesn't bump and thats what im going for.
DJK, I am running them in 4ch mode. I tried bridging over 2 channels and it wouldn't work. so i bought y connectors for the rca's and have 1 sub bridged over ch1 & ch2 and the other sub bridged on ch3 & ch4.
And what do you mean by running one driver per channel in 4ch mode?
If your going for bump then you need to buy a better amp because that one will not hold the load your putting on it as said above so either rewire it or deal with the cutting out and possibly ruin your amp.
"so i bought y connectors for the rca's and have 1 sub bridged over ch1 & ch2 and the other sub bridged on ch3 & ch4."
You can't do that.
"And what do you mean by running one driver per channel in 4ch mode? "
What part of that don't you understand? The amp has four channels, you have two loads. Pick any two channels and hook them up to one load each.
"If i wire them in a series then it doesn't bump and thats what im going for. "
Buy something different.
You can't do that.
Just for the record, the reason the amp was cutting out was because I re-did the tinsel wiring myself and the solder gun loosened the connectors that hold the wire from the speaker to the enclosing box. Every time a certain note hit that caused allot of vibration it would shake the connectors too a point where they would mess up the circuit and short the amp. Took me almost 2 years to figure that **** out. The system slams now, But my amp remains complete garbage. As soon as i get cash it will be replaced, I highly reccomend these speakers though. Great quality
It would seem you have a few choices.
1.) Operate the existing amplifier within it's limits and keep it from protecting itself by wiring the drivers in series.
2.) Continue to overdrive it as you have so that it "bumps" and protects itself whenever a note is played that dips below the impedance that it's comfortable with.
3.) Purchase a new amplifier.
- Subwoofers
- Amp goes into protect mode on high notes
