Amp for Jordan JXR6
Hi Guys,
Im looking into a JXR6 built
I already have a pre amp so Im looking for a poweramplifier to drive the jordans.
One hand I read that the Jordans dont need much power <25W, on th eother hand its rated 100 Watt and its good to have headroom.
So what is the recommended power ?
I have two second hand amps in mind, a Denon POA-F100 which is 3x25Watt (third channel for a sub) or an oldie Sansui B1000, 4x70W.
Any thoughts on the subject ?
Thanks,
Ewald
The JXR6 is probably rated at 100w in system - that is, in use with a passive crossover to a bass driver at 500Hz.
If you're up to a bit of soldering, a pair of Gainclone amps would make a good match. They're available with outputs of 20w to 60w, depending on type. You can then add a bridged gainclone (for up to 120w) for a suitable bass driver. Add in an electronic crossover and you've gone active.
