Amorphous core transformers only work above 20KHz?
Step one, find the decimal point that got moved?
Step two, contact the engineering support at the company, and explain what you want and what you are trying to do.
Since there have been tube output transformers wound with amorphous C cores already, we know it can be done.
The question, iirc, is if the material you got happens to be large enough for the application, and has sufficient permeability at the frequencies of interest. I think that's the bottom line...
Not sure which product ur looking at, since there was no pdf with your post... (dunno how to do that bit myself...). And you didn't specify a webpage or product number.
_-_-bear :Pawprint:
The core can work at lower frequency than 20KHz. Every metal core works in lower region too. Maybe your transformers are designed for other purpose, like switch power supply. There is no need for large number off wire turns in coils becouse they work with high frequencyes (50-100KHz). Higher the frequency , higher voltage is induced in secondary coil.
I'm too damn lazy to read the PDF,
But as frequency increases, less inductance is required to do the job. so. if the core is constant, you need less windings for a higher frequency.
so it's probably wound to work for 20khz, and will not provide enough inductance for lower freq's. i think. 😉
Gasho
Perhaps you want to refer to the following formula:
N= V*10000/(4.44*f*Ac*Bmax)
Where:
N = number of turns
V = Voltage in Vrms
f = frequency in Hertz
Ac = area of section of the core in cm2
Bmax = Maximum induction allowed in Teslas
In my second experience I had 800 turns wound in a core of 9,5 cm2.
I had a setup constituted by a variac a lamp of 60W in serious and the referred bobbin.
I noticed that lamp lit with 170V - 50Hz.
This means that the core was saturated 0.99 Tesla.
According to datasheet this should only happen at 1.5 Tesla
That is the reason I think I was tricked!
Would you not think like this?
Joao
bear said:
Gap?
The gap will effect the saturation point.
_-_-bear
And mu. Actually, it flattens out the mu (in the same brute-force way that a very large bleeder resistor will improve regulation of a power supply, at the cost of a lot of power), with the side-effect that saturation is greater as well (because actually, mu is lower so the B is lower for the same amp-turns....etc....).
Tim
[[Gap?]]
Yes of course!
Due to the deformation of the junction area of the two " C " of the core, I have a unwanted gap.
[[mu?]]
I also think so.
Because the material heated up too much. There it is the reason to have lost some physics characteristics, such as permeability, maxim saturation flux, etc.
Joao
How hot? I don't know about amorphous but iron has to be heated to 1500øF to change any magnetic properties. (Nickel loses it around 800øF. As I recall, gadolinum's curie point is right around room temperature!) Being amorphous, it might crystallize (anneal) if heated above the transition temperature much, after which you have normal steel (again, if it IS steel. I'm too lazy to Google it).
Tim
I don't know how much hot the core was heated.
I noticed the zone of junction of " C"s had a rectification process.
On that zone, where the rectification millstone was passed, the core presents physical deformations. The stack swelled from 19mm to 21mm.
The dielectric between the lamination disappeared in that zone. They are not agglutinated and they are easy to separate with the finger.
This shows a care lack during that mechanical process and shows there was an exaggerated temperature increase.
regards
Joao
The company that supplied me C-Cores has already answered my msgs.
They have made new cores which will be tested for the properties I have advised.
They expect to receive them early next week and will dispatch them to me immediately free cost.
As soon as I receive them I will do some tests and announce new results.
regards
Joao
