Aluminum and Plastic Reaction
Joined 2000
I place a DVD case with a clear plastic sheath on a bare aluminum "Bud" box. When I removed the DVD case, there was an imprint on the case in the aluminum. I also saw this happen when I place a plastic ear bud used for ear protection on aluminum over night.
Can this happen with internal wiring like PVC or Teflon?
I'm worried about desolving a power cable and causing electricution or fire.
Any thoughts?
Thanks,
Vince
Hi Cal,
Well, maybe. The aluminum enclosure contained my Bride of Zen preamp. It doesn't get very hot, just warm. This is definately a reaction. It seems to happen with soft plastics. I'm just concerned it will happen with the wiring of a project.
I'll try to take a picture.
Thanks,
Vince
I belive the "Bud" cast enclosures are not aluminium at all, but Zinc. I may be wrong, and they may be an alloy, but I'm pretty sure they are zinc. The polycarbonate resin that CD's are moulded from is highly modified, but none of the additives should reat with the zinc. At least not quickly.
To VDJ - die casting alloys incorporate some zinc along with the aluminum to make the stuff easier to mash into shape. There's probably a few other goodies in the mix as well. This also makes the resulting alloy easier to drill, not like the usual gooey aluminum. Loading a search engime with "die casting alloys" would probably result in more information than one could ever want....
