• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
altmustech sales thread
New unique Marantz (Elna) 15000uF/71V and 18000uF/71V capacitors. Only USD25,00 each! 4 pcs of each type.
Nichicon 2.2uF 400V Non-inductive Superior performance Polypropylene Capacitors
AP Type 2.2uF 400V Non-inductive Superior performance Polypropylene Capacitors for sale. US$1.5 each. More than 100 pcs.
Specifications
Category Temperature Range: 40 to +85°C
Rated Voltage: 400VDC
Capacitance Tolerance: ±5%
Insulation Resistance: 10000 ΩF or more
Dielectric Loss Tangent: 0.1% or less (at 1kHz 20°C)
Withstand Voltage: × 175%
Category Temperature Range: –40 to +85°C
Ideal choice for AC coupling!
NEC-TOKIN 1F 5.5V FR/FYD type Supercaps only for US$2.5!
FYD Type Characteristics
MAX ESR (at 1 kHz) (Ω): 35
MAX current at 30 min.: (mA): 1.5
FR Type Characteristics
MAX ESR (at 1 kHz) (Ω): 60
Vivaldi M6 Sony CXD1244 and TDA1541 Based DAC module
Vivaldi M6 Sony CXD1244 and TDA1541 Based DAC module for sale. Balanced and unbalanced outputs, galvanic isolation (ADUM1400). Passive LCL filters. Nichicon Muse, Sanyo OsCon and Nissei capacitors. US$250.00 plus shipping.
Any questions?...
Made in Japan
UNI-T New UTD2102CE 100MHz/1Gs Digital Storage Oscilloscope for sale!
UNI-T UTD2102CE 100MHz/1Gs Digital Storage Oscilloscope for sale!
New and boxed, User Manual, two probes, installation CD, power cord.
Bandwidth: 100 MHz
Rise Time: ≤3.5 ns
Sample Range: 1GS/s
Vertical Sensitivity: 2mV ~ 5V/div
Record Length (Max): 2 x 512k
Sample Rate Real time: 1GS/s, Equivalent: 50GS/s
Scan Time Base: 5ns ~ 50s/div
Trigger Type: Edge, Pulse, Video and Alternate
Automatic Waveform Measurements: 28
Ports Standard: USB Device x1, USB Host x1; PASS/FAIL, Optional: LAN RG-45
Mathematics: Add, Subtract, Multiply, Divide, FFT
Display: 64k, Full colour LCD, 320 x 240
The price is ONLY USD390.00 + shipping. Shipping abroad the world! Paypal accepted.
Motorized ALPS-based remote control kit with ext. on/off, sleep and mute functions!
Based on motorized ALPS/Panasonic (two variants) potentiometer volume remote control kit. Mute (Takamisawa relay), power on/off (ext. relay out) and sleep functions are available. Tone compensation (option). Power on and sleep (30 mins) LED indication. Direct TTL 9600 asynchronous serial command out (option). Power rate: 9-12 VDC, 150mA. Any Sony remote control unit. Dimensions: 50mm * 70mm * 25mm. Made in Japan by Amiteq. The price is US$45,00 (!) for basic version (power control, sleep and mute). PayPal is accepted.
Super proposal on DIY market! The best feautures/quality/price ratio! Limited quantity!
Quality PCB prototypes in in 3 days! Low cost for small quantities!
Quality PCB prototypes, 1-6 layers in 3 days! We provides quality PCB prototypes at low cost, with quick turnarounds starting at 12 hours! Our capabilities include FR-4/CEM single- and double-sided, multi-layer boards that are priced for small quantities 2 to 100 pieces. PayPal is accepted. Please PM me for details.
1000 pcs 1% Nissei 1/8W MF resistor kit is only US$25,00 include shipping!
1000 pcs 1% Nissei 1/8W metal film resistor kit is only US$25,00!
Specification:
Power rating at 70℃: 0.125W
Operating Temp. Range: -55℃ to +155℃
Max. Working Voltage: 200V
Max. Overload Voltage: 400V
Dielectric Withstanding voltage: 300V
Temp. Cooficient: ±25ppm/℃
Insulation Resistance: >10000MΩ
Short Time Overload: 2.5 times RCWV for 5 seconds
Low noise, 1% precision
