Alta Hestia Ti - Raal/Morel/Dayton
As reviewed in Stereophile January 4, 2018:
Well, this is an interesting set of choices, I'm still trying to wrap my head around the measurements:
The design is claimed to be a 3-way, though the top mid-woofer is open baffle and Morel, the bottom mid-woofers are sealed and Dayton.
As far as I can tell, the creator is attempting a quasi-open baffle AND a line source at the same time. Also, while the step response is ideal, the frequency is not, telling me the designer prioritized phase matching over amplitude matching, with no explanation for why he could not do both.
Next, if you are going to use mid-woofers, why oh why attempt to pull the Raal tweeter down so low, and so poorly?
Don't get me started on the port.
The article states that the three mid-woofer's outputs are identical. How is this even possible??
Also note the absolutely punishing minimum impedance: Under 2 Ohms around 280Hz. Ouch.
The impedance rise from 1KHz to 10 kHz is likely due to the twetter which is mostly inductive, perhaps in keeping with Raal's philosophy to minimize the HP filter, it probably has 1 cap followed by the tweeter's transformer. As they say in Twitter - "I have questions."
BTW - Normally I find it uncouth to rag on a speaker design like this, certainly in the DIY world, but for $34k a pair, anything that measures this curiously needs to expect some sort of critical discussion.
And they cost 32.000$/pair in USA. In my eyes this is one of the worst ever attempts for a hifi-loudspeaker. Over-engineered without real understanding and control of acoustics and loudspeaker design. In the spcification bass is said too be aperiodic, but we see a regular reflex tube. Bass cabinet resonations at 100/200Hz on the other hand look like poor aperiodic "tuning" Pairing a dipole mid with double closed mid drivers is a mess of interferences like the author said in the footnote... Voicing is bass-heavy and impedance is like a rollercoaster.
I raise my hat for Stereophile staff, the article is very polite but with some criticism based on measured data and listening impressions.
Erik, Juhazi
Reading the review, I can't conclude that the twin bottom M's are in a sealed enclosure. A picture on page 2 shows them and the grille behind and one can see thru the fabric clearly, no enclosure. I could be wrong, please clarify.
Also, the bass loading is not referred to as aperiodic, but rather a (ported at the end of) transmission line, the imp measurement clearly showing the saddle.
Just checking the facts.
