Alps potentiometer channel differential.
I am using a 24 stepped ladder potentiometer using 1% tolerance resistors and the other day I checked the outputs (before soldering in) and it was perfect in both channels😉. on the other hand, I checked an Alps and Noble potentiometers and I measured a big difference between channels, like one channel measured 140 ohms and the other channel measured 147 ohms. sometimes it measured less and sometimes it measured way more. it was "never" matched to the other channel. I never knew it was a big difference from channel to channel. live and learn lol.
AFAIK about 0.3 dB is about the minimum you can detect when using headphones... speaker operation is less critical. Hence <1 dB matching is usually considered fine.
When using 4-gang pots, some manufacturers have added series resistors at the bottom of the first section so you don't get more channel imbalance than with a 2-gang pot.
if you know that your potentiometer is more than a 20% variance between channels, will you use it in your amp that you build using very good parts tolerance like 1%? will it matter to you that one channel is lower or higher than the other?
