Alpine MRV-f545 repair help? (CUR)
Hello everyone.
I have a Alpine MRV-f545 that I need some help in troubleshooting a fault...
Amp works fine at low-mid volume's, However once you start going up high in volume the amplifier shuts off and displays 'CUR' which as I understand is OVER Current.
It's not a Ohm issue, amp is only hooked up to 2 4ohm alpine type r speaker's. Yet amp still goes into this protect mode(CUR)
Gain's are set appropriately.
This amp SHOULD be able to run a pair of r type's with no issues.
Speakers have been running off old 4ch amp for months with no issues, So I know it's not a speaker fault.
I have tested other speakers on the alpine amp, Does the same thing(CUR)
It is definitely a issue with the amplifier.
Wiring is all well and good, Plenty of power via 3 batterys and 2 alternator's.
ground's checked and double checked, there fine.
Even ran a new ground point, amp still faulty.
Rest of wiring has been checked and fine.
RCAs checked and fine.
Ran amp off another seperate power system, still faulty.
I purchased the amp recently from someone online who told me amp was in perfect condition....Thanx!!!!! it's faulty.
Disconnected one of my amp's just to test the new alpine before I permanently install it, And lucky I did because it came up faulty.
I opened the amp up, Everything looks fine, Amp's internals looks new, No burns, burnt smell....anything like that....
If i disconnect all speakers from amp, then turn up the volume it does not go into protect, it only fails when speakers are connected.
Im quiet good at soldering, and the actual repair stage, Just not good at the diagnosis....
Where should I start looking???, What part's should I focus on??
You're help is much appreciated!!!, I would really like to fix the amp...
Ok thanx perry,
So lift either Q806 or D816(any 1 prefered?), then power it up with a 10a fuse.
What should i do then, just leave it run on the bench or in the car?
Sorry, im not all too smart with this.
Ill start pulling it apart now, these alpine amps take a wile to get apart..
Ok so i removed d816, powered it up with a 10a fuse.
No speakers or rcas connected.
Amp turned on as normal, left it on for 5 mins and it was running as norma.
What should i do from here?
Also would you know what d816 diode is, ill need to buy a replacement but can not read numbers on it.
Thanx.
No, sorry i dont have a scope.
I hooked the amp up, then ran each channel on its own, listning very carefully.
Audio was clean on every channel.
I did not turn it up very loud, did not want to push it at this stage with no protection.
It goes into protect at high volume.
Thanx.
