Alpine MRV-1000 repair
Got given it with one channel out with blown FETs and the chassis ground track which i have now replaced. I connected it up to my bench supply to see how it behaved with some power. Set the supply to limit the current and got as far a 4A 4.3V whilst checking voltages. Wasn't sure whether it was a good idea to push the current any higher as i'd rather not blow the FETs, though my bench supply can only go as far as 10A anyway. (wouldn't have expected the amp to require that much for quiescent) Even at this level the repaired side gets warm, whilst the working side remains cold.
Here are the measurements i got if they are of any use:
Repaired channel in red italic (No service manual, so I've numbered them 1 to 4, 1 being closest to the power terminals and 4 being up by the rectifying diodes)
FET 1
Gate - drain 0.01V
Gate - source -4.29V
Source - drain -4.30V
FET 1
Gate - drain 4.24V
Gate - source 0.00V
Source - drain -4.24V
Measuring with ground probe on power ground
FET1/2/3/4 (all measured the same)
Gate 4.30V
Drain 4.31V
Source 0.01V
FET1
Gate 4.24V
Drain 0.03V
Source 4.23V
FET2
Gate 2.20V
Drain 4.25V
Source 0.02V
FET3
Gate 0.02V
Drain 4.25V
Source 0.02V
FET4
Gate 0.02V
Drain 4.25V
Source 0.02V
Switch mode control IC 1 (closest to chassis, reckon this might be the repaired channel, but not certain)
1. 0.02V
2. 0.02V
3. 0.02V
4. 0.02V
5. 0.02V
6. 0.02V
7. 0.02V
8. 2.23V
9. 0.02V
10. 2.20V
11. 2.23V
12. 0.02V
13. 0.02V
14. 0.02V
15. 0.02V
16. 0.02V
Switch mode control IC 2 (further in)
1. 0.02V
2. 0.02V
3. 0.02V
4. 0.02V
5. 0.02V
6. 0.02V
7. 0.02V
8. 2.23V
9. 2.90V
10. 2.91V
11. 2.23V
12. 2.23V
13. 0.02V
14. 0.02V
15. 0.02V
16. 0.02V
Come back to this amp whilst the 3566 is proving troublesome. Tested everything in the iffy channel and all tested good. 4 new IRFZ44's in the psu and it powers up ok, but the current draw is a lowly 0.5A rather than 2.5A as stated in the manual. I've not tried giving it any load as yet but checked the voltages on the 494's and these are the results:
IC801
1. 0.96v
2. 0.96v
3. 3.71v
4. 0.328v
5. 1.58v
6. 5.03v
7. 0.0048v
8. 14.25v
9. 0.16v
10. 0.16v
11. 14.25v
12. 14.25v
13. 5.03v
14. 5.03v
15. 5.03v
16. 0.00v
IC802
1. 0.00v
2. 0.89v
3. 0.08v
4. 0.33v
5. 1.59v
6. 3.81v
7. 0.0047v
8. 14.25v
9. 6.95v
10. 5.40v
11. 14.26v
12. 14.26v
13. 5.03v
14. 5.03v
15. 5.03v
16. 0.00v
Something definitely seems amiss with 802 as pins 9 & 10 are way higher than they should be and pin 3 is way lower.
I've not got a VR601/602 in my copy of the service manual or the one from elekroTanya. 801/802 both have their wipers coming off pin 1 of IC801/802.
Page 5 in my service manual shows the PCB diagram with all of the parts labels. My copy of the MRV-1000 manual is part of the MRV-T300 manual which shows how to set it using TP1 & TP2 where you adjust VR801 to give 52V +/-0.5V across the test points. (obviously this doesn't work with the 1000 as the rail voltages are higher) Test points are across the collectors of the two complementary outputs.
Tried to adjust the rail voltages today and the right channel (IC801/VR801) will adjust and measured 90V between the centre rectifier legs. (was about 94V pre adjustment) The other channel does not change when I attempted to adjust it. What's odd is when I measure the DC voltage between ground and the collectors of the outputs I get -45V on Q222 & Q226 but only 21V on the collectors of Q220 & Q224.
I've checked the waveforms on both 494's for pins 9 & 10 as well as the drains for the inverters. Scope set to DC coupling and zeroed correctly pre measurement.
IC801 - (left channel) Pin 9
IC801 - Pin 10
Q808 - Drain - Will check others for their voltages but, I believe the waveform shape matched. Time/div had to be adjusted to 5us
IC802 - (Right channel) Pin 9
IC802 - Pin 10
Q809 - Drain - I will check the levels on the others again to be sure but believe they matched. There really is that big an offset.
I've not found any leaky capacitors in this amp. I changed the main 3300uF and 470uF parts for new ones anyway. I'll check the voltage between those points. (Centre leg of the rectifier and output collector of corresponding rail)
No voltage drop. I see -20.4V on both the centre leg of the rectifier D804 and -the same on the collectors of Q222 & Q226. I see 42.2V on D802 and the same on the collectors of Q224 & Q220.
The other channel appears to shut down as there is virtually no voltage on the rectifiers.
