This amp powers up but no sound..
I have both + - 15 volts on all op-amps
I also have both + - 32 volts of rail on the outputs..
Any suggestions where to look next?
I don't have any technical information on it but you could do some generic troubleshooting.
Rail-rail oscillation on the output transistors?
Audio through all of the preamp op-amps up to the driver IC?
Are you getting +- 32 vdc on the speaker outputs? If you are the finals are blown.😎This amp powers up but no sound..
