Alpine MRP-M2000
Try an MMBTA06.
The resistor you asked about is a 100k.
You may have blown surface mount fuses. They're under the transformer. They're no fun to change. You can jump one of the open fuses (there are multiple in parallel in two or four groups) with a wire for testing (through a limiter).
As soon as you get it to power up fully, quickly re-check the voltage on Q304/11. If the voltage is greater than about 70v (referenced to ground), change the 06 to an MMBTA42.
