Alpine KTP-445U Buzzing/Popping/Breaking up
After about 20 minutes or so (warming up I guess), the amp starts a popping in the right rear speaker which increases frequency into a buzz.
Here it is at full clip-
https://www.youtube.com/watch?v=jMdkUzihVkA
I have this wired in at speaker level in an otherwise stock system. Its soldered into a harness, so it's using all of the existing power and grounds.
- The buzzing starts after it has warmed up.
- Turning the stereo volume up loud will cause it to stop.
- It will continue with the stereo turned off.
- It will continue with the stereo unplugged from the amp.
- I had noticed in the past the right rear speaker would pop when the car was turned on.
I'm not sure how or why, but it's the amp. It's been fine installed for over a year until this started. How can I begin to diagnose this? What should I be looking at?
