Hi everyone. I'm new to this forum and am looking for a little advice...
After helping a friend with construction of a pair of Frugel Horns, I am fancying building some speakers myself. The design I would like to build is the Alpair 6 Pensil 6 from Mark Audio, or one of the similar designs. It "seems" to be a simple enough design both in terms of woodworking and electronics.
My question concerns the height of the drive unit in the enclosure. The overall height of the enclosure is 37" which is fine. However because my Hifi system stands on an upstand of about 8", it means the drive unit would be too high in relation to my ears when seated.
Can the drive unit be moved further down the enclosure to compensate, or would this compromise the sound in some way?
Am I correct in thinking this is a simple bass reflex design whereby the enclosure volume and port size are critical and other design features not so critical?
Thanks in advance for any advice....
Also.... Could anyone point me in the right direction for a UK dealer for the Markaudio drive units... Thanks again...
Crash Tested,
Welcome to the forum!
The Driver center position is ~7" from the top, so adding back 8" would roughly bring the driver center height 38" - that should be ok? IIRC in the past, folks (a couple of them most likely 🙂) complained that the Pensil driver height seems too low and had requested higher placement of the driver if possible.
That comes to your point of moving the driver - that's a no, no, as it will spoil the alignment. The Pensil is a MLTL variant (as far as I know), and not a BR box - so it is not only about volume and port size - cross section, driver height also matter.
AFAIK the Europe dealer for MA is:
Strassacker: Speaker Building, Components
BTW, are you looking at Alp 6 metal or paper?
Correct, the pensils are a specific MLTL alignment, so the driver is located where it is to reduce pipe harmonics.
Thanks for your prompt advice Zman...
The design I was looking at on the Markaudio website shows an overall enclosure height of 37" and a driver height of 29 1/4" from bottom to centre. So lowering the unit by 8" would bring the driver down to 21 1/4" B to C.
But in any case, if it is a Transmission Line then, (as you say) it shouldn't be moved... Which leaves me back a square one... after a similar design for a full range driver with a driver height of around 22"...
Yes...
I want to build something that similar in "looks" to the Pensil (square section, tall, thin, single driver, fairly easy construction) but a driver height of around 22-23"... The overall height isn't too important...
If you know of anything along those lines, it would be useful...
Thanks again...
Thanks again...
Crash Tested,
If you haven't decided 100% on the Alp 6, maybe you can consider EL-70 or CHR-70. Check out The folded Half Tower here:
http://www.frugal-phile.com/boxlib/microTower-maps-290412.pdf
Looks like a straightforward build. The cabinet is 18.5" high with driver center at ~13 inch. Looks like you'll need a stand.
For the EL70 or the CHP the tuning would need adjustment.
Pensil for the A6.2s was never released as he felt the stress on the driver was too high.
dave
dave
the 6 does work very nicely in the "milli" sized enclosures, but of course has more overall limitations of attainable SPL / bass extension than any of the 70mm models ( CHP/ R & EL 70, and Alpair7.3)
Zia's reference would be the drawing on page 7 of 13 - keep in mind this was designed for CHR & EL70 - use cautiously with the 6P or M
That one actually only done for CHR70
dave
dave
I see that now - the only one of the six just for the CHR - maybe an old guy could be excused for getting confused
Thanks for all your help chaps...
I'm not in any way tied to the Alp 6... Just liked the design of the Pensil...
I've looked at the design for the folded half tower as you suggested and it looks pretty good. Can you tell me if all the internal panels are bracing panels? If so could the cabinet be made of 18mm or higher but keeping the same internal dimensions?
As I'm fairly new at all this, some of your references are a little lost on me...
Not sure what an EL70 driver is, or a "milli sized enclosure"
Thanks again for your help...
Pensil for the A6.2s was never released as he felt the stress on the driver was too high.dave
Would the same be true for the Morgan and Riley MBVR's?
http://p10hifi.net/FH/download/English-Auto-Series-061109.pdf
- More Vendors...
- Planet 10 hifi
- Alpair 6 Pensil 6
