hi,
has anyone try alpair 5 from markaudio? i've been thinking and thinking to use fullranger and ssingle sdx7, either jx92s, or planet10's fe167en or alpair 5 which is kind of interesting
cheers
cheers
They're brand new, so I doubt there'll be many people here who've had a chance to listen to them. Looks like they've had Ted Jordan's input (always a good thing) so I imagine they'll be pretty good, albeit low sensitivity & needing that supporting bass unit. From a brief look, the 2 way on the Markaudio site looks like a reasonable enough design if you want a bookshelf cabinet.
i'm just worried not enough SPL for big room, i;m planning to set it on 30 sq.m room
i seen some kits on css from occam audio, seems interesting also
i know u have an extensive listening with the jordans scottmoose, do u think its agood idea to pair jx92s with alpair?
cheers
cheers
I'm not scottmoose, and I have little experience with the Jordan and none with the alpair, but it seems to me that you'd use _either_ the Jordan or the alpair, and supplement whichever you choose with whatever is needed to approach full-range in a bookshelf design. With the alpair, you'd clearly need a woofer, and with the Jordan, you could possibly add a tweeter. The Jordan and the alpair overlap so much in terms of usable frequency response that it would seem like a waste to use both in one design. You'd have plenty of choices in terms of a crossover point, however, if you did. ;-) - Pat
yes pat, i think so. i have jx92s, and i find it very good, just the high not that detailed.
i just worried that the spl would not be enough for the alpair 5 to fill the room
thanks pat for ur opinion
The Alpair was the Jordan J6T in a previous life. These are the parts that Mark Audio had all tooled up for Jordan before the dramatic events.
I have an unused pair here, Gregg the Geek and i have been playing with the J6T in preparation for these.
They fill the same niche as the FF85k, the jury is still out but the Fostex has the edge.
dave
dave
i've been thinking to use hardwood for the enclosures, since its avail in the philippines, and they have 30cm planks with 2-3m length so i just thought its a good idea.
anyone?
anyone?
I think this is actually Greg the Geek's project, and the woofer is likely one of the Silver Flute drivers on sale at Madisound for less that $30 each.
polka dots are extra
_henry_ said:whats the woofer for the jx92s? u running open baffle?
can u pls tell me more?
That is the Jordan J6T + Silver Flute 5 1/2".
It is Gregg the Geeks. I just did the drivers up for him.
dave
i thought j6t need the box to work properly.
i'm looking something simple, and the kit from occam mt 27 seems suitable for my need (which i will power them with NAD c370, i dont have ewxperience with the tubes yet) they are well priced and comes with the passive, which helpful for beginner like me, but i do not know yet what design they are using, but they say crossed in 300hz area, so that will be a good start.
any opinion ?
thanks dave.
any opinion ?
thanks dave.
_henry_ said:i'm looking something simple, and the kit from occam mt 27 seems suitable for my need (which i will power them with NAD c370, i dont have ewxperience with the tubes yet) they are well priced and comes with the passive, which helpful for beginner like me, but i do not know yet what design they are using, but they say crossed in 300hz area, so that will be a good start.
any opinion ?
Is the occam the Alpair + ansd SDX7. I use the SDX7 alot. I don't know if Occam are doing the essential modification needed on the woofer. Even if not, it is easy to do yourself.
We've been playing with the FF85 + the SDX7 with fabulous results amd letting Gregg go ahead with Aplair/J6T project development.
Gregg's design is for those without the budget for SDX7.
dave
yes, they say its a custom alpair 50.
they have a dedicated enclosure for the alpair, and ported for the sdx7
http://www.occamaudio.com//~stores/29645_preview.jpg
what kind of modifications that u done dave other than Enabl?
i know u have an extensive exploration for the sdx7 🙂
cheers
cheers
There are two versions of the Alpair 5 and Occam uses the copper coloured one but it is not custom. The SDX7 as used is also stock.
There may be a modified version of the SDX7 available shortly.
We are eagerly awaiting the Alpair 6 (in both round and rectangular baskets) as well as the Alpair 10 bass and the Alpair 10 full range and expect that these will be available sometime in September. They will be shown at Rocky Mountain Denver in October in the Lucid/Occam/CSS room 2032.
Bob
Bob
CSS/XBL said:Hi,
Bob
Wow, that's some exciting news.😀
_henry_ said:what kind of modifications that u done dave other than Enabl?
If you run your finger or your finger nail over the cone of the stock SDX7 you get a really ugly noise... 3 coats (each successive coat with less) will hold the carbon fibre strands in place making it much quieter.
dave
thats a very good news indeed from the markaudio, i guess they really trying to replace the not so sure future of the jordans 🙂
i see, so the sdx7 not very smooth cones eh..
thanks dave
thanks dave
_henry_ said:i see, so the sdx7 not very smooth cones eh..
Stock the carbon fibre strands are just lying "loose" on the surface of the impermeable backing layer (some sort of plastic). Bonding all these together makes a significant improvement.
Hopefully Bob can get them to do that at the factory for the mext batch.
dave
_henry_ said:yes pat, i think so. i have jx92s, and i find it very good, just the high not that detailed.
I've tried them in a room of similar dimensions, crossed to an SDX7 at 300Hz, and wasn't all that happy with the effect. Imaging was so-so and they have an unnatural "lispy" (can't think of a better word) sound at higher frequencies
planet10 said:The Alpair was the Jordan J6T in a previous life. These are the parts that Mark Audio had all tooled up for Jordan before the dramatic events.
dave
My quest to find a perfect partner for my SDX7s has led me to purchase pairs of not only Alpair5, but FF85k, FE127e, and FR125s. I have them crossed to the SDX7 (300Hz, active), and on a switchbox so I can compare them. Findings so far:
Alpair5 - see comments above
FF85k - what a magnificant little beast. Better power handling _henry_ than the Alpair5. Work very well with the SDX7. More natural sound than Alpair5. Seem to handle a wide range of music. I agree with dave (although my jury has reached it's verdict on this one).
FE127e - not impressed at first, but getting hooked as they break in. Certain types of music (vocals, classical) are quite hypnotic. More complex music can sound quite ordinary. Much more "forward" sounding than the FF85K. Match ok to SDX7.
FR125s - very versatile - actually have 2 pairs in bipole arrangement. Sound superb but a very different effect (much more mellow) than the other drivers I have. Match very well to SDX7.
The playing continues...
- Full Range
- alpair 5 from markaudio
