Almost Free Sub Cabs, West Wilts, UK
We have had two sets of panels for a subwoofer cabinet CNC machined from 25mm high grade MDF. There was either a slight error in the drawing supplied to the machinist, or they input the routing incorrectly, as the top panel needs a bit more taking off to sit flush, the amp panel has not been recessed and the driver cutout and recess is too small diameter for our particular 12 inch driver.
None of these issues would matter to a DIYer as they would need changing to suit you anyway. We don't have the time to mess about with these and have changed the design since as well, so these are taking up space under my stairs.
Internal volume is approx 40 litres, outer dimensions 400mm x 400mm x 500mm WxDxH.
May be able to deliver in West Wiltshire area if petrol costs are covered or some lucky arrangement is made. Asking £10 each cab just to cover messing about, otherwise these are going to the recycle place. Cost over £50 each to have made - the quality is excellent.
