ALL-DSP Model "PLP-226" (PLP226) several Questions
DSP Model "PLP-226" (PLP226) from ALLDSP (ALL-DSP) several Questions
A friend of me uses this three-way DSP crossover unit to drive a corner horn (diy-version from Klipsch - go to
Klipschorn Floorstanding Speakers | Klipsch® )
so as the koax-driver 4590 from BMS-PRO - go to
Bundle | BMS 4590 (8 Ohm) an 2 Zoll 190 Hz Traktrix Kugelwellenhorn (
together with JABO horn similare to follow:
http://images20.fotki.com/v106/photos/6/111916/8324195/IMG_3554-vi.jpg
http://www.abload.de/img/1z574b.jpg
The DSP-crossover is follow:
https://www.alldsp.com/product-plp226.html
https://www.alldsp.com/product-plp-226-oem.html#
AllControl | Top Apps 24
http://www.doyleaudio.com/downloads/amps/alldsp_broschuere_2010_kurven_5.pdf
equipped with follow ICs:
OPA1664 at inputs and outputs
AK5388AEQ (4-CH-ADC from AKM)
M12l64164A-AZY1P35WX (dynamic RAM from ESMT)
UDA1338H (4+1-CH ADC/6-CH DAC from NXP)
UD1103L-1 (3-times, unknown part, from ALL)
PETA8 ACD4 (unknown part, outline: SO-14)
I need an owner's manual (user manual/instruction manual) only for the functions on the keypad at the frontplate for all operating instructions without additional personal computer and associated LCD display)
Who can I download this ?
Additional I want to know, which jitter value is present ?
Thank you for helping.
The German company ALLDSP only does OEM work and doesn't sell their stuff to the public. This advice I receive today via email.
This means, that I must find out, which brand use this DSP mainboard in their DSP models. So I can order the owner's manual and service manual from there.
Who know such brand names ?
Thank you nfor your advices.
P.S. Accidentally I found this model from ohm, that is similar bot not identical to the above mentioned OEM DSP:
http://ohm.co.uk/wp-content/uploads/manuals/cred_MK2_manual_19-07-07.pdf
