im a little confused over the volumecontroll circuit in the aleph preamps p1.0 och p1.7 they just seems to be switching in and out resistor in series with the signal but the shunt resistor is the same .... dos´nt it usualy is the other way around?......
wouldnt the circuit described in the other thread concearning a balanced volyme controll be better?
/micke
/micke
Hi there,
I thought I knew that circuit, but I had to go back and have a good look at it to figure it out.
The point to note is that all the relays are double throw types, and in the circuit as drawn, they all connect the resistors to ground and the output is unconnected to the input. As a relay turns 'on', it connects the audio to the output plugs via a resistor, but note that all of the other resistors are still connected to ground, and that is where the attenuation comes from.
In effect Pass seems to be altering both the series and shunt resistor values.
I'm going to feed the resistor values into a spreadsheet and work out the attunuation values and output impedances.
Cheers, Adrian
Cheers, Adrian
aaaaahhhh im blind im blind.....where did everything go?!...
btw thanks i get it now...i missed the ground sign on the left side...
/micke
/micke
This attenuator works complex. It connects resistors in series and others to ground. It´s more complex then a shunt resistor attenuator and the load is very different at different attenuations. It takes a while to calculate this circuit but it IS logarythmic.
