Aleph Pass One Monoblocks
Hello
I'm Marc from France
I'm new on this forum...
I have a pair of Aleph Pass One monoblocks
Not a lot of informations about those amps...
I think they need to be recaped
Can you please tell me what kind of caps I could find for those amps ?
Do I have to do something else ?
Thanks a lot
Marc
Aleph 1
120 lbs. per channel 🙂
150 watts at 8 ohms.
300 watts at 4 ohms.
The Aleph 1 doubled the power of the Aleph 0. and had the same 3 gain stages.
All following Alephs from the 1.2 on - went to two output stages - sounding better, but losing
the ability to double down their power into tougher loads. The new improvement was the
"Aleph current source".
-->i never saw a service manual for the 1, but i'm sure if you looked at the Aleph 0 manuals
you'd get some help
from pictures - obviously late amp iteration , without much electrolyt caps ..... except main reservoir ones
if you have hum , even without preamp connected (or with XLR shorted on all pins) , there is definitelly need to replace those caps
however , due to physical execution of contacts to pcb , it seems you're pretty much stuck with cap dimensions , primarily regarding pinout spacing .
height and dia , that can be varied , with some ingenuity
so , 22 to 33mF per each , 75Vdc ....... good luck in finding them ......
it'll help if you measure their dimensions (dia , height , pin spacing) and post here ....... and - maybe it will help you in search - that type of cans is usually called computer grade
It seems like the original part is still available:
http://www.mouser.fr/ProductDetail/...Ux/Er7vwMzb2x%2bIg50xtCcw1AX6u9W4lwrtZa4hrA==
Here's a slightly lower capacitance, higher voltage and cheaper alternative:
http://www.mouser.fr/ProductDetail/...RpZPHVy%2bjtQuXjWPKFKB4rpZCm6%2bHpYmBZUXJsZFR
This one should be a good fit, but not stocked:
http://www.mouser.fr/ProductDetail/...=sGAEpiMZZMtZ1n0r9vR22caJrJGgYX4Idp3QbjM3BjU=
Good luck with your search and restoration effort.
Dennis
P.S. Beautiful amp you have!
