B Bengali Member Joined 2006 2010-05-07 8:11 pm #1 2010-05-07 8:11 pm #1 Hi, for Aleph P1.7, what is lowest value you could use for the output coupling? I will be using 5K attenuator on the output. Is 4.7uF too low for input coupling caps? I was thinking of trying those ZEN Caps per Mr. Pass's suggestion. thanks.
