I have to do a final netlist check, but all comments are welcome.
I'm thinking of reserving more room for in and output coupling caps.
And has anybody made an Aleph X P 1.7?
Yes,it might be hard to fit some audiophile quality polypropylene caps.Did you use Protel for this one?
Bartek
Bartek
No, I used Ultiboard 2001. When the board was almost finished I got sosick of UB I started to search for a replacement and found protel dxp. Unfortunatly layouts are not exchangeble for as far as I know. And finished it in UB.
What are the dimentions of such caps?
update
I finished the new lay-out.
The couple caps are now 25mm x 40mm. To save space, all the small stuff has to be placed on the other side then the couple caps.
The TO-92 devices have now a slightly different package.
And it fits on a standard 160mm x 100mm pcb.
The components have the same numbering as the Aleph P 1.7 Service manual.
And a final question: What would better for the gain pot? A normal pot or just a simple adjust pot.
- Aleph P 1.7 pcb
