i want to use t-network caps
in the psu for the aleph mini
based on the board from kk pcb how do
i keep either half seperate? won't they be
connected at 0 volt? making them into an
ordinary capacitor? any suggestions please
More information on the parts you are using - do you have a manufacturer part number and/or link?
changed my mind! going to use 6 x 22000uf 63v 105 degree
evox rifa peh169 instead. easier & it's the first project for me
Totaly overkill, I promise you, first just build it with like two 10000uf ones you have lieing around. I think G rollins, the father of the mini, used 3300uf or something small like that.
Mine is currently 22000uf - 150 milliohm - 10000uf.
ok mebbe just 4 lol. i'm using two 15V secondaries. do i need to use inrush limiting if so does the thermistor sit in parallel or series on the ac input
thanks again
mike
thanks again
mike
