Aleph and F5 amp calibration
I would like to make sure that the output levels on my amps are as close as possable. How would I go about measuring this in the most simple way ? ( I dont have a scope ) I want to then calibrate them. How do most people do this?
regardss
dave
I doubt there will be enough difference to worry about but...
If you applied an idenical signal to both chanels any difference
in gain would show up berween the output of channel 1 and the
output of chanel 2. Here you could even use a speaker connected
between the output of channel 1 and the output of channel 2
as a VERRY sensitive indicator any difference in gain between
channels.
