First off all please forgive me my ignorance...I'm brand new in forum like this, so please understand mistakes of newly logged... I decided to build my Pass Aleph 5. Where can I find all that is needed to build this amp?I mean schematic,PCB,list off parts, and in case of need suggestions and and advices...My regards!
Schematics, list of parts: Aleph's service manuals, somewhere at www.passlabs.com/aleph.htm , pcb layouts - there are plenty on that forum, most popular are Mark Finnis', BrianGT's and Panos' (I believe, I hope I did not offend anyone by forgetting 😉) , if I recall correctly, even the One and Only has promised to post his own original layouts, but it seems he has more important things to do 🙂. Help - also here, do search if you need anything. Ah, and finally: powodzenia. Daj znac, jak Ci idzie 😉.
Greg,
The first thing you should do is go back quite a few pages in the Pass Labs threads here and read all there is pertaining to what you want to build. You will learn more that way than any other. You will also run across the PCB's while you're reading through.
You might want to consider Point to Point wiring them as it is not a very complicated circuit and the parts count is low. P to P usually sounds better anyway.
Mark
Mark
