Aleph 5 DIY- with Dolphin sounds...Help please
Hi All
My trusty DIY Aleph 5 has been running flawlessly for a few years but recently has started playing up..ONE channel only
First symptoms:
at turn on some dolphin sonar type chirping- then settled done after a few seconds.
the other day the suspect channel went dead- as in no sound - a ittle thump fixed this - (Dry joint?)
I opened it up to have a look to find that 2 of the output mosfets on the -ve rail have been running very hot - I have white stickers with writing on them from when they were matched.- the stickers having turned brown.
note each channel has 3 mosfets per rail - total 6 / channel.
voltage across each source resistor (1 ohm) by each mosfet on neg rail appr 1.4v , 0.6v 0v (yes 0v) (replaced this mosfet 3 times....)
pos rail all about 0.6v. across 1ohm resistors
Now i've checked for dry joints by reflowing each junction.
All transistors on board have been replaced
neg rail mosfets all replaced (matched).
result is 23v at speaker terminals with no load.
two hot mosfets (one very hot ) and one cold one..
Any ideas anybody?
Many thanks in advance
easiest way - desolder one end of all output source resistors , same as one end of all output gate resistors
power up - check voltages on input LTP ( voltage across R9 in Algar's schm will tell everything )
solder back resistors for one by one vertical pair of outputs ; power up and measure offset and voltage across source resistors
enclosed schmatic is'n exactly clear - did you measure some of voltages acroos resistors or you measure them ref. GND
sometimes is problem to find what's main reason for output offset , without isolating input LTP from outputs ; that's the reason why I wrote that
however , maybe for first step - just desolder one end of all output gate resistors ; that way , they will be unbiased , so you can check operation of LTP
if any of mosfets is damaged , it will draw enough current unbiased , so you will see excessive current through it's source resistor
sometime is best and fastest way - just unsolder all semis (one by one ) and check then separately
http://firstwatt.com/pdf/art_mos_test.pdf
Hi Voltage across r106 = 5.75v...
I loved the show "Flipper " as a kid...
that means you have 5V75/221R ~ 26mA through LTP , which is good
now - time for checking output mosfets
first with buzzer on DVM , to see is there any with substantial shortie between pins
then with diode test ( there must not be any conductance between pins )
then either per Papa's pdf , or connecting one by one vertical pair in amp itself
Tried testing one vertical pair
Smoked 221R resistor on adjacent moset (disconnected)
bummer
will try the long way - mosfet testing individually.
Spare amp now in service - Digitech AA-0476 - bought cheap - see other thread.
Now i know what it sounds like....
Cheers
