Hello!
I am going to bulid a Aleph 1.2. I have bought
Heatsinks H=50cm L=30cm W=4cm.
2 X 4KVA /45 Volt transformer.
12 x 100000uF Evox REFA
4 x 68 A 600V Bridge Rectifier
50 X IRFP 240(Same production)
Solen Capacitors
Tantalm resistors
And so on!
I am planing to reduce the 1.5 ohm resistor that is placed on the drain of IRFP 240 to 1.2 ohm. I am doing this so I can get even more out of this already powerful amplifier.
Is there anybody that have any experience in doing so?
Best regards Torsom
Solen Capacitors
Tantalm resistors
And so on!
Best regards Torsom
You won't get more power out of an Aleph by reducing the Source resistor (I am assuming that you meant Source resistor, as there is no resistor on the Drain of the output devices)...unless you are using a low impedance load. The power into 8 ohms will remain the same. Increasing the bias can make it sound better, however. I have a pair of Aleph 2s running at roughly 10% higher bias than stock and they sound quite nice.
If you want to increase the amp's power into 8 Ohms, you'll need to increase the rail voltage. Yes, it can be done, but you'll have to pay close attention to the thermal dissipation of the MOSFETs.
Grey
Grey
Joined 2002
why do yoneed so much power ? I'm running 4 aleph mini's witch = 15watts each Class a.. ANd have tons od power WHY do you need a aleph 1.2 plusmore power ? Do you really have so much money to run them and the hydro bill up. ? Do yo have huge huge huge heat sinks ?
Thanks for correcting me GRollins! Yes, I meant the source resistor.
Ok! So reducing the resistor vil mostly cause higher thermal dissipation and maybe better sound.
I got the tips from KRISTIJAN KLJUCARIC, maybe i misunderstood him. He talked about 900W and right below 8A BIAS. I guess he meant 900 W in heat dissipation.
And when I think about it, as long as you have the same voltage and the same impedans(load) the effect will be the same. Ohms lov🙂
And for "jleaman"! You asked me if I need the extra power. No! I don't need it. Somethings you just do for the fun of it and the satisfaction of getting things to work. And about the money! It's an expensive hobby and I hope I don't blow all the MOSFET's🙂
Best regards Torsom
Best regards Torsom
So long as you go into it with realistic expectations, chances are that everything will turn out just fine.
Grey
Grey
I'm in the process of finding appropriate heatsinks for the aleph 1.2. If I'm not mistaken I am also thinking of having heatsinks just on the sides. However, I've been troubled with getting the C/W ratio low enough. I figure I can have the amps running at 35 degrees above idle, but only a few, and very expensive heatsinks, can give me these low numbers and only just. We're talking about a two heatsinks for $800 (500 mm W, 200 mm long and 85 mm high).
The question is this: Have you calcultated the temp for the heatsinks under normal operation, and if so - where can I get these heatsinks?!?
I sidestepped the whole problem. Fooey on convection heatsinks. I went water-cooled for my big Alephs. Works wonders and it's much, much cheaper than buying a zillion dollars worth of heatsinks.
I did a thread on this a couple of years ago if you're interested. Bang on the search feature a while and it'll turn up.
If you decide to go with normal air-cooled heatsinks, you might want to consider fans. It'll help keep your costs down. If you don't want to use fans, then you'll be spending a lot of money. That's just the way things are, I'm afraid.
Grey
Grey
Hi. Look from elfa, they have austerlitz heatsinks, KS300.6 might be good for you. http://www.elfa.se/pdf/75/07562267.pdf
Four Seifert KL273 or something like that
http://www.seifert-electronic.de/index.php
http://www.clofis.nl/nl/seifert/Seifert_Katalogus2002.pdf
I'm also planning to build a pair of Aleph 1.2 to use with the Apogee Diva's. It'll be my first DIY project though.
Can someone (Torsom ?) email me your parts list ? Any rough indication of how much the parts only will cost ? (besides the PCB's from KRISTIJAN KLJUCARIC).
I've considered smaller Alephs, but the Diva's are power hungry and quite inefficient (3 ohms, 87 db). I'm currently using the Diva's with a Krell KSA-200S, but would like to bi-amp. The Krell's bass is excellent, but the MRT could be improved. I've read wonderful reviews about the Aleph's MRT sweetness (a recurring trait since earlier designs such as the STATIS). So, I'm keen to give it a try and hope that it won't cost too much
If you send me your email address I can send you the details of my project. I have found a dealer who has given me a lot of help and has managed to give me a good offer on quality parts for the Aleph 1.2. Actually, he supplies everything but heatsinks. www.RT-audio.nl. Send him an email and he'll be sure to help you out!
With regard to the heatsinks I have have finally opted for 4x fischer SK535 (500x200x86[mm]). Two for each channel. This gives a c/w of 0.06. In addittion I will install a low noise (9dB) fan, and adjust it so it is virtually silent, just enough to ensure convection through the amp.
These heatsinks are expensive, but if I want my design to be more conventional than the original - this is the penalty! (6400Nkr without taxes and shipping).
- Aleph 1.2
