Akai reel to reel channel bias problem?
I have an Akai gx-270d with a problem I've not been able to identify for years. When I record and playback in forward mode, the right channel has more midrange and loss of treble. When I flip the recorded tape around and play it in reverse mode, it's all fine. I've connected test signal on the forward playback head and it comes out the same on both channels which suggests to me that preamps are ok.
I've put it down to two things, faulty head but it looks fine without wear or a Bias. I get similar sound results when I mess around with bias on my Naka 600 - more midrange, treble, etc. But I dont' even know if it is possible the adjust bias only on one channel on the Akai. Maybe it's some other problem, I'd welcome any suggestions, maybe someone has similar experience. I'm sick of playing my tapes backwards only.
