I have at home Akai gx620 tape reel deck. A lot of Akai-s and also mine had problems with 2sc458transistors. I replace them all with 2sc1815 and one dead chanell is playing again ok and values vs service manual are in 5% region.
The only problem that stayed is defect rec head. One winding has 5,6ohm and recording is ok another winding 1 ohm and no recording is working on that channel. Electronic is ok because if i swich wires on pcb and record with other channel it records normally.
Has anybody any source of Rec head code R4-241 it is the same for 620, 625, 635, 4000....
Thank you.
Thank you.
