Aikido Phono Amp Output Tubes 12AU7 and 12AX7?
Aikido Phono Amp Manual Page:
The manual is at the bottom of the page
At long last: the Aikido Phono Preamp
Aikido Phono Amp:
Aikido Phono Preamp Kit
I am needing help on choosing which tubes to pair up together. I am needing more gain since I am using a Denon Dl 160 Cartridge, which is rated at 1.6v.
I was thinking of the 12AX7 for the input stages V1, V3, V5, V7 but I am not sure what to use for the output tubes V2, V4, V6, V8. I see the 12AU7 and the 12AT7. I am not sure of which one to use.
I do need to use quiet tubes because of my speakers being Electrostats.
What are the differences in the 12AU7 and 12AT7?
P.S.
On a side note, I found an excellent electronics book at a local book sale. It was a copy of the book Electronics Made Simple 1965
Amazon.com: Electronics Made Simple (9780385012270): Henry Jacobowitz: Books
The book really delves into tube and discusses tube amps. I had some newer books but they really did not discuss tube in depth.
The 12AU7 is lower gain (mu ~ 20) vs. 12AT7 (mu ~ 60). The 12AU7 has lower plate resistance compared to the 12AT7. The 12AT7 has about double the Gm. Lastly, they bias differently, just generally different tubes.
The output stage tubes are working as cathode followers (with a TubeCAD twist of course). I would say that a better suited tube for these stages would be either the 12AT7, if you use one of the above, or a 6922. You could also look for 6BK7's or 6BQ7's as they will work in these positions and also provide low output impedance. As a bonus they are cheap, ranging between $2.00 to $10.00 each for NOS examples.
12AX7's should work fine in the first positions if you need the gain. If you can find them reasonably priced, look for 7025's, the low-noise Hi-Fi 12AX7. 5751's may offer slightly lower noise being lower gain, but your phono amp will have less gain as well. There are other low noise 12AX7's out there, JJ ECC803s come to mind for new production. You could also try and track down CBS 7729's, though they seem to be exceedingly rare and pricey. I tracked down one NIB at a surplus store a couple of years ago by dumb luck, I have never seen another one.
:cheers:
Hello JPeitzman,
Thank you for the through response. As I am new to tubes it helps with understanding why I would choose a certain tube.
I will do a search and see if I can find some of the tubes you suggested.
Do you have any places online that has good prices on Tubes. I am little hesitant with EBay. Although, once I know what I am doing with tube amps, I will be scouring Ebay for some to try out with my amp. I try to stay away from Ebay because I usually will find something of interest.
Some good places to start:
Antique Electronic Supply
Welcome to TubeDepot.com!
thetubestore.com Audio and vacuum tubes for your amplifier.
Angela Instruments Online Catalog - Home
The TubeDepot and The Tube Store I would use mostly for new stock, some of their NOS tubes seem a bit inflated. At the first three sites you can't always find your tubes in the broad categories, it's much easier just to type them in the search box.
Other good sites for some tubes (Nebraska Surplus) and for parts (all):
Surplus Sales of Nebraska
DigiKey Corp. | Electronic Components Distributor | United States Home Page
Mouser Electronics - Electronic Component Distributor
Allied Electronics ? Electronic Parts and Components Distributor
Hope this helps!
:cheers:
I just built the Aikido Phono Preamp. I used 6n1p for all 8 tubes, sounds good, just make sure you use Rk of 200-300. I also plugged in 6n2p's and that was good too, much higher gain than the 6n1p. And on top of that, 6n1p and 6n2p tubes are super cheap on Ebay.
^^^Did you happen to re-bias or anything, or just plug them right in? The 6N2P is more akin to the 12AX7 and operates different from the 6N1P. The in 6N1P is more like a 6922, though it kind of wishes it was a 6922, the 6N23P is the better Russian 6922. If these tubes will work in this design I would look for 6N2P's for the front end and 6N1P's or better, 6N23P's for the outputs. They are cheap, you don't have to feel bad if you kill a few, and if you don't like them you don't have to feel bad tossing a $1 tube in the desk draw.
6N2P-EV / 12AX7 / ECC83 tube - Hi Fi audio tubes - Tubes-Store.com
^This is the high reliability military version selected for low noise
6N1P-EV / 6DJ8 / ECC88 / 6922 tube (own box) - Hi Fi audio tubes - Tubes-Store.com
^Military version with extended life
6N23P-EV / E88CC / 6DJ8 tube - Hi Fi audio tubes - Tubes-Store.com
^The better 6922 equivalent, again Military extended life.
:cheers:
No, I didn't rebias. I just plugged them in. I suppose I should make the Rk a higher value than 300 for the 6n2p to compensate for the higher gain, but I didn't want to resolder everything as I as pretty happy with the 6n1p sound. I think I might get some 6n23p's just to play with as I am happy with the other soviet tubes so far.
I have used 12at7 for input and 12au7 for output for an aikido phonostage.
I also have used 5751 input and 12au7 with great results.
The 12AU7 isn't really the greatest valve for this purpose. Maybe you should consider trying a 12BH7A or ECC99 there.
Much higher current capabilities, lower Zout, better soundstaging.
Cheers, 😉
There really is no such thing as universal swapping of pin compatible tubes, without proper bias there's no way to know what's going on even when one thinks it "sounds" just fine...
Cheers, 😉
Cheers, 😉
Thanks for the tip.
I know that the 12au7 is not that good, but I have a bunch of them and if fed higher current, they suffice.
My favorite tube for that position (output tube on an aikido) is the 7119 or the 5687.
Tube-o-philes love to bash the 12AU7, yet with the other hand they are quite happy to recommend the 12AT7, with its equally poor linearity but MUCH worse grid current. The 12AU7 ain't that different from the venerated 6SN7 (lower capacitance though!). From what I can tell the anti-12AU7 thing is 90% snobbery. I love 'em.
<shurg> Everyone is entitled to their opinion. However, "Valve Amplifiers" Volume 3 page 187 and 188 has a comparison table of medium mu valves. I think it speaks for itself. So there is data that indicates that the 12AU7 is not as low in distortion as other Medium Mu tubes.
YMMV
Doug
How many components would I have to unsolder if I change my mind and want to try the 12AU7s?
I would think that it would only be a couple of resistors to switch from 12AT7 tubes to 12AU7. Is this correct? I would not mind comparing the tube sounds. I really do not want to go over budget so would possibly try the tubes in a couple of months or if I found a great deal.
I try to just let my ears do the listening. I use an old Technics 1600 SL with a Denon 160 cartridge and have no desire to upgrade, even though some people criticize the direct drive tables. The phono player sounds great to me and that is really what is important in the end. I think tubes will be the same for me.
You are correct. It is 2 resistors. However, since the circuit that we are talking about is a follower plus active load with 100% local feedback, you are probably not going to hear a dramatic difference. The 12AX7 should dominate the sonic signature. However, feel free to experiment and learn.
