Did anyone try to connect an AES/EBU source to the Wolfson WM8804 receiver chip?
What is the correct implementation for this input?
Thank you.
Thank you.
For single ended input you need 110 ohm resistors to ground or a digital pulse transformer in single ended or balanced configuration.
Thanks for your reply.
Maybe I was unclear:
Provided a balanced AES/EBU source, may I connect an AES-3 high level signal, range 2 to 7 Vpp, (through a 1:1 pulse transformer) to the WM8804.
Datasheet on page 11 only states:
Or:
would it be better to use a 1.21:1 pulse trafo followed by an 8:1 (-18dB) passive attenuator, to derive 0.5/0.6Vpp to feed 8804 s/pdif input?
Please refer to fig. 1 of this application note:
Interfacing AES3 & S/PDIF
(The WM8804 supply will be 3.3V for both digital and pll sections -DVDD and PVDD-).
Any comment/suggestion?
Thank you in advance.
, no mention on level compatibility.Supports AES-3 data frames
Or:
From what I can see in the datasheet you are limited to the PS voltage or slightly lower. A properly terminated AES 3 signal will be attenuated 6db (3.5V max) but that is still too high if the source is full rated signal level. A 1.21 stepdown pulse trafo would be your best bet and you shouldn't need any more attenuation.
Best, Bill
Best, Bill
I have heard about people using HiFace with DACs equiped with WM880x. Hiface has output level well beyond SPDIF specification, maybe even beyond AES PRO. I wouldn't use Wolfson for AES/EBU, better solution seems to be CS8416 with some ASRC...
